jQuery UI Widgets › Forums › Navigation › Menu, Context Menu › jqxmenu RTL issue
Tagged: item, jqxMenu, level, Menu, right to left, RTL, setItemOpenDirection, submenu
This topic contains 4 replies, has 2 voices, and was last updated by raj 10 years, 9 months ago.
Authorjqxmenu RTL issue Posts
Hi all,
Here last menu has sub items, i need rtl options for lastmenu only, not for all the menu items. How we can achieve this, consider the following code to resolve my issue.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title></title> <script src="../Assets/Scripts/jquery-1.11.1.js" type="text/javascript"></script> <script src="../Assets/jqwidgets/jqx-all.js" type="text/javascript"></script> <link href="../Assets/jqwidgets/styles/jqx.base.css" rel="stylesheet" type="text/css" /> <link href="../Assets/Styles/css/font-awesome.css" rel="stylesheet" type="text/css" /> <script type="text/javascript"> $(document).ready(function () { // Create a jqxMenu $("#menu").jqxMenu({ width: '125px', mode: 'vertical', autoCloseOnClick: false }); }); </script> </head> <body> <div id="menu" style="float:right;"> <ul style="padding-right: 4px; padding-left: 4px; cursor: pointer"> <li><span>First</span></li> <li><span>Second</span></li> <li><span>Third</span></li> <li><span>Fourth</span></li> <li><span>Fifth</span> <ul id="columnfield" style="padding-right: 4px; padding-left: 4px; cursor: pointer"> <li><span> <input type="checkbox" id="checkbox1" />First </span></li> <li><span> <input type="checkbox" id="checkbox2" />Second</span></li> <li><span> <input type="checkbox" id="checkbox3" />Third</span></li> <li><span> <input type="checkbox" id="checkbox4" />Fourth</span></li> <li><span> <input type="checkbox" id="checkbox5" />Fifth</span></li> </ul> </li> </ul> </div> </body> </html>
Hello raj,
Right-to-left can only be applied to the whole menu. However, you may use the method setItemOpenDirection to change the open direction of some item’s pop-up (example).
Thanks for your quick support, I can achieved what i excepted, but It is possible to change the arrow position to left side. please refer the code<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title></title> <script src="../Assets/Scripts/jquery-1.11.1.js" type="text/javascript"></script> <script src="../Assets/jqwidgets/jqx-all.js" type="text/javascript"></script> <link href="../Assets/jqwidgets/styles/jqx.base.css" rel="stylesheet" type="text/css" /> <link href="../Assets/Styles/css/font-awesome.css" rel="stylesheet" type="text/css" /> <script type="text/javascript"> $(document).ready(function () { // Create a jqxMenu $("#menu").jqxMenu({ width: '125px', mode: 'vertical', autoCloseOnClick: false }); $("#menu").jqxMenu('setItemOpenDirection', 'Home', 'left', 'down'); // create checkboxes // $("#checkbox1").jqxCheckBox({ checked: true }); // $("#checkbox2").jqxCheckBox({}); // $("#checkbox3").jqxCheckBox({}); // $("#checkbox4").jqxCheckBox({}); // $("#checkbox5").jqxCheckBox({}); $("#lblcreategroup").click(function () { $("#btnsave").show(); $(this).hide(); $(txtgroup).show(); }) var temp = "<li><i class=\"fa fa-html5\"></i><span style=\"\">Export HTML</span></li><li><i class=\"fa fa-file-pdf-o fa-fw\" style=\"margin-left: -3px;\"></i><span style=\"padding-left: 5px;\">Export PDF</span></li>"; $("#grouphorizontalline").append('<li><span id="currentgroup" style="padding-left: 3px; font-style: italic;" onclick="setcurrentgroup()">Current Group</span> </li>'); }); </script> </head> <body> <div id="menu" style="float:right;"> <ul style="padding-right: 4px; padding-left: 4px; cursor: pointer"> <li><span>First</span></li> <li><span>Second</span></li> <li><span>Third</span></li> <li><span>Fourth</span></li> <li id="Home"><span>Fifth</span> <ul id="columnfield" style="padding-right: 4px; padding-left: 4px; cursor: pointer"> <li><span> <input type="checkbox" id="checkbox1" />First </span></li> <li><span> <input type="checkbox" id="checkbox2" />Second</span></li> <li><span> <input type="checkbox" id="checkbox3" />Third</span></li> <li><span> <input type="checkbox" id="checkbox4" />Fourth</span></li> <li><span> <input type="checkbox" id="checkbox5" />Fifth</span></li> </ul> </li> </ul> </div> </body> </html>
Hi raj,
Unfortunately, the arrow direction can only be changed by setting rtl to true, but, as I stated, this would affect the whole menu.
Thanks for your kind support.
Raj -
