jQuery UI Widgets Forums Navigation Menu, Context Menu jqxMenu not loading with remote json
This topic contains 3 replies, has 2 voices, and was last updated by  defyent 1 year, 8 months ago.
  • defyent
    When I use localdata with a json based jqxMenu, my menus load fine, however when I transfer this to url based json my menus are blank, no menus display at all. I can see in my server logs that my source.txt is being called, and my json data is valid, but nothing is loading. Any ideas what I’m doing wrong?
    You can view my example at https://new.datahangar.co.nz/templates/index.html
    jqxMenu not loading with remote json #133449
    You can load it this way:
    // var data = [{
    // “id”: “1”,
    // “text”: “Operations”,
    // “parentid”: “-1”,
    // “subMenuWidth”: “250px”
    // “id”: “2”,
    // “parentid”: “1”,
    // “text”: “Flight Schedule”
    fetch(‘./source.txt’)
    .then(res => res.json())
    .then(data => {
    var menu_source = {
    { name: ‘id’ },
    { name: ‘parentid’ },
    { name: ‘text’ },
    { name: ‘subMenuWidth’ }
    localdata: data,
    var menuDataAdapter = new $.jqx.dataAdapter(menu_source);
    menuDataAdapter.dataBind();
    var menu_records = menuDataAdapter
    .getRecordsHierarchy(
    ‘id’,
    ‘parentid’,
    ‘items’,
    map: ‘label’
    $(‘#topmenu’).jqxMenu({
    source: menu_records,
    height: 25,
    //width: ‘99.9%’,
    //autoOpen: false,
    //autoSizeMainItems: true,
    //theme: ‘metrodark’,// less than this number will minimize menu
    I hope this helps!
    Svetoslav Borislavov
    https://www.jqwidgets.com/
    jqxMenu not loading with remote json #133451
    defyent
    Thank you for the quick reply, the above solution has a scope error, as menu_source can not be accessed outside of the .then statement. If I define menu_source before the fetch, I get the following error.
    ncaught TypeError: Cannot read properties of undefined (reading ‘beforeLoadComplete’)
    at new $.jqx.dataAdapter (jqxdata.js:636:21)
    at HTMLDocument.<anonymous> (index.html:71:39)
    at j (jquery-1.11.1.min.js:2:27244)
    at Object.fireWith [as resolveWith] (jquery-1.11.1.min.js:2:28057)
    at Function.ready (jquery-1.11.1.min.js:2:29891)
    at HTMLDocument.J (jquery-1.11.1.min.js:2:30257)
    jqxMenu not loading with remote json #133452
    defyent
    Nevermind, I replicated the code wrong. All working now. Thank you again !
