jQuery UI Widgets Forums Navigation Menu, Context Menu jqxmenu li padding and anchor click
This topic contains 2 replies, has 2 voices, and was last updated by  Peter__Pan 7 years, 9 months ago.
  • jqxmenu li padding and anchor click #94946
    Peter__Pan
    <div id="jqxDictionaryMenu">
                <ul>
                    <li><a href="~admin/colors" class="menu-link" data-target="body">Colors</a></li>
                    <li><a href="~admin/manufactures" class="menu-link" data-target="body">Manu</a></li>
                </ul>
     $('#jqxDictionaryMenu').on('itemclick', function (e) {
                    $("#body").load(e.target);
                    //$('#' + $(e.args.children[0]).data("target")).load($(e.args.children[0]).attr("href"));
                    return false;
    But LI in menu has class
    .jqx-menu-item-top {
    border: 1px solid transparent;
    text-indent: 0;
    list-style: none;
    padding: 4px 8px 4px 8px;
    left: 100%;
    overflow: hidden;
    color: inherit;
    right: 0;
    margin: 0px 1px 0px 1px;
    cursor: pointer;
    So my a-tag is not stretched in LI and if I click out the a (even a.menu-link {display: block;})
    next code from jqxmenu.js is running
    f.addHandler(c, "click", function(c) {
                        if (!b.disabled && !f.disabled && (f.keyboardNavigation && (f.activeItem && a(f.activeItem.element).removeClass(f.toThemeProperty("jqx-fill-state-focus")),
                        f.activeItem = b,
                        a(b.element).addClass(f.toThemeProperty("jqx-fill-state-focus")),
                        f.minimized && c.stopPropagation()),
                        f._raiseEvent("2", {
                            type: "mouse",
                            item: b.element,
                            event: c
                        f.autoOpen ? !f.autoCloseOnClick || g || f.clickToOpen || b.closeOnClick && (c.data = f,
                        f._closeAll(c)) : b.level > 0 && (!f.autoCloseOnClick || g || f.clickToOpen || (c.data = f,
                        f._closeAll(c))),
                        g && f.autoCloseOnClick && (c.data = f,
                        b.hasItems || f._closeAll(c)),
                       "A" != c.target.tagName && "a" != c.target.tagName)) {
                            var d = null != b.anchor ? a(b.anchor) : null;
                            if (null != d && d.length > 0) {
                                var e = d.attr("href")
                                  , h = d.attr("target");
                                null != e && (null != h ? window.open(e, h) : window.location = e)
    and it is not that I want, because it returns partial html in page instead in target-element
    How to prevet it? Thanks!
    jqxmenu li padding and anchor click #94991
    Hello Peter__Pan,
    Please, avoid posting code from our sources, because it is illegal.
    About the mentioned case I would suggest you type validation and recognize when clicking on the correct place then it happens desired action.
    if(isAnchorTag) {
    	// Do logic
    jqxmenu li padding and anchor click #95029
    Peter__Pan
    thanks, Hristo, but your solution is not good for me, and events from jqmenus.js still running
    as temporarly solution I did so to prevent standart behavior
    $(e.args).unbind('click');
    and edit some css
    li.jqx-menu-item-top > a.menu-link {
        display: block;
        padding: 4px 8px;
    .jqx-menu-item-top, .jqx-menu-item-top:hover {
        padding: 0px !important;
