jQuery UI Widgets › Forums › Lists › ListBox › jqxlistbox,not working,problem with ID
Tagged: javascript listbox, jQuery ListBox, jqwidgets listbox, jqxListBox, ListBox, not working, problem with ID
This topic contains 2 replies, has 2 voices, and was last updated by Zabelsky 7 years, 6 months ago.
Hello.
I open modalvar modalInstance = $uibModal.open({ animation: true, templateUrl: "app/Views/Models/smsLogModel.html", backdrop: 'static', controller: "smsLogController", size: "lg", resolve: { tractorId: function() { return $scope.objectToSmsLogController; } } }); modalInstance.result.then(function(data) { }, function() { });
In controller i was created listbox:
var listSource3 = [ { label: 'Тип смс', value: '_StateSms', checked: true }, { label: 'Сообщение', value: 'Text', checked: true }, { label: 'Водитель', value: '_WhoSend', checked: true }, { label: 'Экспедитор', value: 'Forwarder', checked: true }, { label: 'Экипаж', value: '_Drivers', checked: true }, { label: 'Дата', value: '_Date', checked: true }, { label: 'Устройство', value: '_DeviceType', checked: true }, { label: 'Пользователь', value: '_CreatedBy', checked: true }, { label: 'Номер', value: 'TractorRegistrationNumber', checked: true }, { label: 'Тел/Имей', value: '_PhoneImei', checked: true } ]; $("#pow").jqxListBox({ source: listSource3, width: 50, height: 50, checkboxes: true }); At from html: <code><div id="pow"></div></code> But when i want open the modal, i have next issue at console: Error: Invalid Selector - #pow! Please, check whether the used ID or CSS Class name is correct. at n.fn.init.a.fn.(anonymous function) [as jqxListBox] (http://localhost:1466/Scripts/jqw/jqxcore.js:7:9521) at Object.<anonymous> (http://localhost:1466/app/Controllers/Models/smsLogController.js:134:27) at Object.e [as invoke] (http://localhost:1466/Scripts/angular.min.js:39:19) at Q.instance (http://localhost:1466/Scripts/angular.min.js:80:122) at http://localhost:1466/Scripts/angular-ui/ui-bootstrap-tpls-1.2.5.min.js:13:31829 at http://localhost:1466/Scripts/angular.min.js:120:113 at m.$eval (http://localhost:1466/Scripts/angular.min.js:134:398) at m.$digest (http://localhost:1466/Scripts/angular.min.js:131:427) at b.$apply (http://localhost:1466/Scripts/angular.min.js:135:161) at HTMLButtonElement.<anonymous> (http://localhost:1466/Scripts/angular-touch.min.js:12:142) What
s happenned ?
thx for answer
with best regards,AlexeiHello Alexei,
It seems this happens because you try to create this widget asynchronously or before the <div/> tag to be created in the HTML page.
Could you provide me more details, what are you trying to achieve and what platform do you use? (“$uibModal.open”)Best Regards,
Hristo HristovjQWidgets team
http://www.jqwidgets.comYou were absolutely right.
Thank you for answer
I reorganized the code to create the widget by pressing on button.
This problem was due to the fact that i try to create this widget asynchronously at uibModal
P.S. I`m used angularJS
Have a good day,Hristo.
U r best -
