jQuery UI Widgets › Forums › Angular › jqxListBox not updating in Unit Test
This topic contains 3 replies, has 2 voices, and was last updated by Ivo Zhulev 7 years, 3 months ago.
I think I’ve finally isolated this to something having to do with the jqxListBox widget, but I have an integration test I’m trying to run, and no matter whether I use
fixture.detectChanges()
orfakeAsync()
along withfixture.whenStable()
, the listbox just will not render in the test.Here’s the relevant template code (I just tried replacing the listbox with a simple
*ngFor
and THAT renders.<div *ngIf="isOpenErrorsVisible && hasOpenErrors"> <jqxListBox #openErrorsListBox (onSelect)=handleListBoxSelection($event) [width]="'100%'" [source]="openErrors" [displayMember]="'message'" [valueMember]="'errorType'"> </jqxListBox> --> </div>
My test
fit('should load the error listboxes with just the right errors', () => { let errorList = sampleErrors; comp.processErrors(errorList); expect(comp.hasOpenErrors).toEqual(true, 'hasOpenErrors true'); //this expectation passes expect(comp.openErrors.length).toBe(1, 'one open error in object'); //and this one expect(comp.isOpenErrorsVisible).toEqual(true, 'open errors visible'); //and this one fixture.detectChanges(); fixture.detectChanges(); fixture.detectChanges(); //getting desperate here let openErrsListbox = fixture.debugElement.query(By.css('jqxlistbox')); expect(openErrsListbox).not.toBeNull('listbox exists'); //this expectation also passes let openErrs = openErrsListbox ? openErrsListbox.queryAll(By.css('.jqx-listitem-element')) : []; expect(openErrs.length).toBe(2); //this one fails });
I’ve verified the <jqxlistbox> element exists (but of course, it’s defined in the template), its items aren’t rendering.
Has anyone else had trouble with this, or figured out how to get the listbox (or perhaps other widgets) to render their content in a test?
Finally figured it out when I googled the right thing: “Angular 3rd party component not rendering during test”
Being new at this, my assumption is that if the page/component works when I do
ng serve
it should work in test, but you have to import and declare in your TestBed any third-party components:import { jqxListBoxComponent } from 'jqwidgets-framework/jqwidgets-ts/angular_jqxlistbox'; ... beforeEach( async(() => { TestBed.configureTestingModule({ declarations: [EduComponent, jqxListBoxComponent, TextBoldDirective], providers: [], schemas: [], imports: [ NgbModule.forRoot(), ReactiveFormsModule, FormsModule ] })
Well, so much for that. While adding the declaration was definitely needed, it seems there’s still something wonky going on with the entire component being seen by the unit test. Even though the whole thing displays on screen, with list items, querying for it in-test returns null:
let item = fixture.debugElement.query(By.css('.jqx-listitem-element'))
returns nullBut if I debug and pause on that line, in the Chrome console using jquery,
$('.jqx-listitem-element')
returns the DOM element.Hi jdh,
Something is missing from that test, cuz as you see the element is fully working and okey.
I shall look into that. If you find an answer, please post it.Best Regards,
IvojQWidgets Team
