This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 9 years, 4 months ago.
  • tigerA155
    Hello, please HELP.
    `$(“#proc”).jqxInput({height: 20, width: 200,
    displayMember:”f40_desc”,
    valueMember: “f40_proc_id”,
    minLength:1,
    source: function(key,response){
    var dataAdapter = new $.jqx.dataAdapter
    datafields:
    { name: ‘f40_proc_id’ },
    { name: ‘f40_desc’ },
    { name: ‘f40_sort_flag’}
    url: “BMS107V1.jsp”,
    data:
    action:”getProcList”,
    //pagesize: 12,
    caltotal:0,
    aa:’test’,
    pagesize:15,
    sortdatafield:’f40_proc_id’,
    sortorder:”asc”,
    pagenum:0
    autoBind: true,
    formatData: function (data) {
    data.startWith = key;
    return data;
    if (data.result.rows.length > 0) {
    response($.map(data.result.rows, function (item) {
    return {
    label: item.f40_proc_id+”-“+item.f40_desc,
    value: item.f40_proc_id
    $(“#proc”).bind(‘mouseenter’, function () {
    var w_isOpened = $(“#proc”).jqxDropDownList(‘isOpened’);
    if (!w_isOpened) {
    $(“#proc”).jqxDropDownList(‘open’);
    IS NOT WORKED.
    Hello tigerA155,
    In above code use same element for two different widgets that is not possible.
    The widget “jqxComboBox” could to be more useful for Your needs.
    Please take a look this example: http://jsfiddle.net/txhi/n9org9v9/
