jQuery UI Widgets Forums Grid JQXGrid Virtualmode Load State
This topic contains 1 reply, has 2 voices, and was last updated by  Stanislav 7 years, 3 months ago.
  • JQXGrid Virtualmode Load State #98500
    bgilzean32
    I’m working with JQX Grid version 5.5.0 and few things I see is happening. When I have virtual mode set to true, and I try to load the state, it loads but what happens is that the sub rows underneath the header are no longer available for selection. If I do get selected row indexes, it will return -1 all the time. The only thing that can be selected is the header of the group.
    Could you please help out with this?
    JQXGrid Virtualmode Load State #98512
    Stanislav
    Hello bgilzean32,
    I did some testing with a grid in virtual mode and a function for rowIndex, with a save/load state.
    Notting wrong happened in my test, it all worked correctly.
    Can you please provide us with an example of the issue you are experiencing?
    Stanislav
