jQuery UI Widgets Forums Grid jqxgrid virtual mode initial filter is not working
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 6 years, 5 months ago.
  • sonu
    I’m using jqxgrid virtual mode for server side data. so everything is working fine without initial filter but when i try to used some initial filter so the request is being sent to server two time. one with the data and one without data so can you please check my code i want to load the initial filter with virtual mode.
          datafields:
              {name: 'id', type: 'number'},
              {name: 'last_name', type: 'string'},
              {name: 'store', type: 'string'},
              {name: 'item_descriptor', type: 'string'},
              {name: 'repairer_name', type: 'string'},
              {name: 'product_brand', type: 'html'},
              {name: 'is_floor_stock', type: 'bool'},
              {name: 'days', type: 'number'},
              {name: 'created', type: 'date'},
              {name: 'updated', type: 'date'},
              {name: 'repairer_status', type: 'string'},
              {name: 'is_extended_warranty', type: 'bool'},
              {name: 'is_inhome', type: 'number'},
              {name: 'is_sandbox_mode', type: 'number'},
              {name: 'callcentre', type: 'number'},
              {name: 'retailer', type: 'string'},
              {name: 'phone', type: 'string'},
              {name: 'product_serial_number', type: 'string'},
              {name: 'replacement_serial_number', type: 'string'},
              {name: 'unique_product_identification', type: 'string'},
              {name: 'repairer_reference_number', type: 'string'},
              {name: 'model_no', type: 'string'},
              {name: 'product_id', type: 'number'},
              {name: 'apn_no', type: 'number'},
          url: 'http://testapi-application.localhost.com/cases/search',
          datatype: 'json',
          pagesize: 20,
          type: 'post',
          root: 'Rows',
          cache: false,
          sortcolumn: 'id',
          sortdirection: 'desc',
          data: {
            params: basicFilters,
          filter: function (filters, data, length) {
            $('#jqxgrid').jqxGrid('updatebounddata', 'filter')
          sort: function () {
            $('#jqxgrid').jqxGrid('updatebounddata', 'sort')
            if (data != null && data.length > 0) {
              source.totalrecords = data[0].TotalRows
            $('#jqxgrid').jqxGrid('updatebounddata', 'data')
      var addfilter = function () {
        var filter_or_operator = 1;
        var filtervalue = 'In store awaiting dispatch to repairer';
        var filtercondition = 'equal';
        var filter1 = filtergroup.createfilter('stringfilter', filtervalue, filtercondition);
        $("#jqxgrid").jqxGrid('addfilter', 'repairer_status', filtergroup);
        $("#jqxgrid").jqxGrid('applyfilters');
        loadComplete: function (data) {  },
        loadError: function (xhr, status, error) { },
        downloadComplete: function (data, status, xhr) {
          document.body.classList.remove('reactloader');
          altrows: true,
          width: 1106,
          showfilterrow: true,
          showsortmenuitems: false,
          virtualmode: true,
            return obj.data
          ready: function () {
            addfilter()
          sorttogglestates: 1,
          autoshowloadelement: false,
          autorowheight: true,
          columnsheight: 40,
          enablebrowserselection: true,
              text: 'Id',
              columntype: 'textbox',
              width: '100',
              cellsalign: 'center',
              datafield: 'id',
              text: 'Customer',
              datafield: 'last_name',
              hidden: false,
              text: 'Store',
              datafield: 'store',
              hidden: false,
              text: 'Product',
              datafield: 'item_descriptor',
              hidden: false,
              text: 'Brand',
              width: '100',
              datafield: 'product_brand',
              hidden: false,
              text: 'Repairer Name',
              datafield: 'repairer_name',
              hidden: false,
              text: 'Age',
              width: '100',
              datafield: 'days',
              filtertype: 'number',
              cellsrenderer: function (row, column, value) {
                return '<div class="jqx-grid-cell-middle-align">' + value +
                  ' days</div>'
              text: 'Status',
              datafield: 'repairer_status',
              filtertype: 'checkedlist',
              filteritems: new $.jqx.dataAdapter(repairerSource),
              filter: firstNameColumnFilter,
              createfilterwidget: (column, htmlElement, editor) => {
                editor.jqxDropDownList(
                  {displayMember: 'label', valueMember: 'value'})
    Martin
    Hello sonu,
    This topic is duplicated.
    Please, refer to the following Post.
    Martin
