jQuery UI Widgets › Forums › Grid › jqxGrid – Uncaught TypeError: r.evaluate is not a function
This topic contains 10 replies, has 2 voices, and was last updated by Hristo 4 years ago.
in my code I have a jqxGrid which is initialized as follows:var sourceDatabases = null; function initDatabaseGrid() { sourceDatabases = { datatype: "array", datafields: [ { name: 'DatabaseSN', map: 'DatabaseUID>DatabaseSN', type: 'string' }, { name: 'DatabaseName', type: 'string' }, { name: 'Description', type: 'string' }, { name: 'CreationTime', type: 'date' }, { name: 'LastItemUpdate', type: 'date' }, { name: 'ModelVersionSN', map: 'ModelUID>ModelVersionSN', type: 'string' }, { name: 'Loaded', type: 'bool' }, { name: 'NoMarkets', map: 'Stats>NoMarkets', type: 'string' }, { name: 'NoCategories', map: 'Stats>NoCategories', type: 'string' }, { name: 'MissingItems', map: 'Stats>MissingItems', type: 'string' } ], id: 'DatabaseUID>DatabaseSN', localdata: [] }; var dataAdapter = new $.jqx.dataAdapter(sourceDatabases); $("#databaseGrid").jqxGrid({ width: '100%', theme: 'metro', source: dataAdapter, pageable: true, autoheight: true, sortable: true, altrows: true, enabletooltips: true, editable: true, filterable: true, selectionmode: 'multiplerows', columns: [ { text: 'ID', datafield: 'DatabaseSN', editable: false, width: '24%'}, { text: 'Name', datafield: 'DatabaseName', editable: false, width: '8%'}, { text: 'Description', datafield: 'Description', editable: false, width: '14%'}, { text: 'Creation time', datafield: 'CreationTime', cellsformat: 'dd/MM/yyyy HH:mm:ss', editable: false, width: '12%'}, { text: 'Last item update', datafield: 'LastItemUpdate', cellsformat: 'dd/MM/yyyy HH:mm:ss', editable: false, width: '12%'}, { text: 'Model', datafield: 'ModelVersionSN', editable: false, width: '24%'}, { text: 'Loaded', columntype: 'checkbox', datafield: 'Loaded', filterable: false, sortable: false, width: '6%'} ] }); }
The content of the jqxGrid is dynamically updated as follows:
function updateDatabaseGrid(newDatabases) { sourceDatabases.localdata = newDatabases; $("#databaseGrid").jqxGrid('updatebounddata'); }
In 15-20% of cases, the dynamic update of the grid generates the following error:
Uncaught TypeError: r.evaluate is not a function refresh file:.../GUI/jqwidgets/jqxgrid.js:8 resumeupdate file:.../GUI/jqwidgets/jqxgrid.js:8 update file:.../GUI/jqwidgets/jqxgrid.js:8 n file:.../GUI/jqwidgets/jqxgrid.js:8 databind file:.../GUI/jqwidgets/jqxgrid.js:8 databind file:.../GUI/jqwidgets/jqxgrid.js:8 updatebounddata file:.../GUI/jqwidgets/jqxgrid.js:8 invoke file:.../GUI/jqwidgets/jqxcore.js:15 jqxWidgetProxy file:.../GUI/jqwidgets/jqxcore.js:15 b.jqx.jqxWidget/b.fn[h]/< file:.../GUI/jqwidgets/jqxcore.js:15 jQuery 2 h file:.../GUI/jqwidgets/jqxcore.js:15 updateDatabaseGrid file:.../GUI/src/database.js:324
I noticed that if in the grid set the “filterable” property to “false” the error never occurs (but I need the grid to be filterable)
I tried to update the grid with other strategies as well, for example resetting the “source” property or calling the “clear” and “addrow” methods. In all cases the error occurs with the same frequency.
jqwidgets version used: 11.0.1
Hello EmilioP,
Thank you for all these details.
I would like to mention one common mistake.
It seems that you use a function to declare the jqxGrid (theinitDatabaseGrid
function).
You should be sure that the initialization of the widget happens just once.
This is very important because it is a reason that causes many issues.
I would like to suggest you update the source only and try to use theupdatebounddata
method (depends on the case you should add an additional argument for sorting or filtering, for example).
Please, take a look at this forum topic, too:
https://www.jqwidgets.com/community/topic/updatebounddata-with-sort-and-filter/Best Regards,
Hristo HristovjQWidgets team
https://www.jqwidgets.comHi Hristo Hristov, thanks for the reply.
I’m sure I call the initialization function only once.I noticed that, if I let few seconds pass between the initialization and the first update, the error no longer occurs.
However, it seems strange to me that the error is due to this.
Any thoughts on this?Hello EmilioP,
It looks like that one operation is not finished before you execute another one.
I would like to suggest you look at this forum topic it could be helpful.Best Regards,
https://www.jqwidgets.comHello Hristo Hristov,
I also thought it was due to this, but I did some tests and it doesn’t seem like that.First I tried to check, before each update call, if the previous grid binding was complete, using the
$("#databaseGrid").jqxGrid('isBindingCompleted')
method. However,isBindingCompleted
always returns true (and thus the previous binding is completed) even when the error occurs.Then I tried to call (the first time) the update method using the
bindingcomplete
event, as follows:var sourceDatabases = null; var isFirstBinding = true; function initDatabaseGrid() { sourceDatabases = { datatype: "array", datafields: [ { name: 'DatabaseSN', map: 'DatabaseUID>DatabaseSN', type: 'string' }, { name: 'DatabaseName', type: 'string' }, { name: 'Description', type: 'string' }, { name: 'CreationTime', type: 'date' }, { name: 'LastItemUpdate', type: 'date' }, { name: 'ModelVersionSN', map: 'ModelUID>ModelVersionSN', type: 'string' }, { name: 'Loaded', type: 'bool' }, { name: 'NoMarkets', map: 'Stats>NoMarkets', type: 'string' }, { name: 'NoCategories', map: 'Stats>NoCategories', type: 'string' }, { name: 'MissingItems', map: 'Stats>MissingItems', type: 'string' } ], id: 'DatabaseUID>DatabaseSN', localdata: [] }; var dataAdapter = new $.jqx.dataAdapter(sourceDatabases); $("#databaseGrid").on("bindingcomplete", function (event) { if (isFirstBinding) { isFirstBinding = false; updateDatabaseGrid(newDatabases); } }); $("#databaseGrid").jqxGrid({ width: '100%', theme: 'metro', source: dataAdapter, pageable: true, autoheight: true, sortable: true, altrows: true, enabletooltips: true, editable: true, rowdetails: true, filterable: true, selectionmode: 'multiplerows', columns: [ { text: 'ID', datafield: 'DatabaseSN', editable: false, width: '24%'}, { text: 'Name', datafield: 'DatabaseName', editable: false, width: '8%'}, { text: 'Description', datafield: 'Description', editable: false, width: '14%'}, { text: 'Creation time', datafield: 'CreationTime', cellsformat: 'dd/MM/yyyy HH:mm:ss', editable: false, width: '12%'}, { text: 'Last item update', datafield: 'LastItemUpdate', cellsformat: 'dd/MM/yyyy HH:mm:ss', editable: false, width: '12%'}, { text: 'Suite model', datafield: 'ModelVersionSN', editable: false, width: '24%'}, { text: 'Loaded', columntype: 'checkbox', datafield: 'Loaded', filterable: false, sortable: false, width: '6%'} ] }); } function updateDatabaseGrid(newDatabases) { sourceDatabases.localdata = newDatabases; $("#databaseGrid").jqxGrid('updatebounddata'); }
Note: the update function in the code above is simplified, actually inside it I have an ajax call to retrieve the new databases to insert into the grid, which if successful executes
updatebounddata
(point where the error is generated)Furthermore, I discovered that, even waiting a few seconds between the initialization of the grid and its first update, the error can still occur, but more rarely (while in a comment above I said that it never occurred waiting few seconds)
Hello EmilioP,
I would like to ask you – do you try the approach from the mentioned topic?
Also, if this does not help you please, provide us with one simple example that demonstrates your case.Best Regards,
I took a look at the topic mentioned above, but I don’t think it solves this error.Some considerations on the example that I will report below:
A) if you want to run it you will have to take care of the server side and modify theENDPOINT
variable in thedatabase.js
file;
B) the home page has a list of sections on the left, in the example shown there is only the database section (for simplicity) but in the real version there are more sections that can be visited by the user that modify the right part of the graphical interface;
C) the example assumes there is ajqwidgets
folder inside the same folder where the following files are locatedThe example consists of the following 4 files:
1) index.htm
<!DOCTYPE html> <html lang="en"> <head> <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" /> <meta name="viewport" content="width=device-width, initial-scale=1 maximum-scale=1 minimum-scale=1" /> <title id="Dashboard">TEST</title> <meta name="viewport" content="width=device-width, initial-scale=1 maximum-scale=1 minimum-scale=1" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.metro.css" type="text/css" /> <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.1/jquery.min.js"></script> <script type="text/javascript" src="jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="jqwidgets/jqxdraw.js"></script> <script type="text/javascript" src="jqwidgets/jqxbargauge.js"></script> <script type="text/javascript" src="jqwidgets/jqxchart.core.js"></script> <script type="text/javascript" src="jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="jqwidgets/jqxlayout.js"></script> <script type="text/javascript" src="jqwidgets/jqxribbon.js"></script> <script type="text/javascript" src="jqwidgets/jqxdatatable.js"></script> <script type="text/javascript" src="jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="jqwidgets/jqxtabs.js"></script> <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="jqwidgets/jqxresponse.js"></script> <script type="text/javascript" src="jqwidgets/jqxsplitter.js"></script> <script type="text/javascript" src="jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="jqwidgets/jqxprogressbar.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.grouping.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="jqwidgets/jqxexpander.js"></script> <script type="text/javascript" src="jqwidgets/jqxsortable.js"></script> <script type="text/javascript" src="jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="jqwidgets/jqxlayout.js"></script> <script type="text/javascript" src="jqwidgets/jqxwindow.js"></script> <script type="text/javascript" src="jqwidgets/jqxinput.js"></script> <script type="text/javascript" src="jqwidgets/jqxnotification.js"></script> <script type="text/javascript" src="jqwidgets/jqxloader.js"></script> <script type="text/javascript" src="jqwidgets/jqxtextarea.js"></script> <script type="text/javascript" src="jqwidgets/jqxtooltip.js"></script> <script type="text/javascript" src="jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="jqwidgets/jqxexpander.js"></script> <link href="base.css" rel="stylesheet" /> </head> <body> <div style="visibility:hidden;" id="mainSplitter"> <div class="splitter-panel" id="leftPanel"> <header class="clearfix"> <div class="container"> <div class="header-left"> <div id="logo" class="suite"> <div id="logoName">test</div> <div id="logoVersion">v1.0.0</div> </div> </div> <div class="freeSpace"></div> <div id="listContainer"> <label for="open"> <span class="hidden-desktop"></span> </label> <input type="checkbox" name="" id="open"> <nav> <a href="#" id="1"><p>  Database</p></a> </nav> </div> </div> </header> </div> <div class="splitter-panel" id="rightPanel" > <!--Database--> <div id="database" class="container-fluid"> <div id="databaseGridTitle" class="widget-title">Database List</div> <div id="databaseButtons"> <button id="refreshDatabase">Refresh</button> </div> <div id="databaseGrid"></div> </div> </div> </div> <script type="text/javascript" src="main.js"></script> <script type="text/javascript" src="database.js"></script> </body> </html>
2) main.js
'use strict'; $(document).ready(function () { $('#mainSplitter').jqxSplitter({ width: '100%', height: '100%', orientation: 'vertical', resizable: false, showSplitBar: false, panels: [ { size: 235}, { size: '87%'} ] }); $('#mainSplitter').css('visibility', 'visible'); $('nav a').on('click', function (event) { $('nav a').removeClass('active'); $('#' + event.currentTarget.id).addClass('active'); $('#database').css('display', 'none'); if (event.currentTarget.id === '1'){ initDatabaseSection(); $('#database').css('display', 'block'); } }); });
3) database.js
'use strict'; // TODO: set the endpoint! var ENDPOINT = '****'; var databaseSectionAlreadyInit = false; var sourceDatabases = null; var rowsDatabaseSelected = new Set(); function initDatabaseSection() { if (!databaseSectionAlreadyInit) { initRefreshDatabase(); initDatabaseGrid(); databaseSectionAlreadyInit = true; } updateDatabaseGrid(); } //#region REFRESH BUTTON function initRefreshDatabase() { $("#refreshDatabase").jqxButton({ width: '80', height: '27', theme: 'metro', disabled: true }); $("#refreshDatabase").on('click', function (event) { updateDatabaseGrid(); }); } //#endregion //#region DATABASE GRID function initDatabaseGrid() { sourceDatabases = { datatype: "array", datafields: [ { name: 'DatabaseSN', map: 'DatabaseUID>DatabaseSN', type: 'string' }, { name: 'DatabaseName', type: 'string' }, { name: 'Description', type: 'string' }, { name: 'CreationTime', type: 'date' }, { name: 'LastItemUpdate', type: 'date' }, { name: 'ModelVersionSN', map: 'ModelUID>ModelVersionSN', type: 'string' }, { name: 'Loaded', type: 'bool' }, { name: 'NoMarkets', map: 'Stats>NoMarkets', type: 'string' }, { name: 'NoCategories', map: 'Stats>NoCategories', type: 'string' }, { name: 'MissingItems', map: 'Stats>MissingItems', type: 'string' } ], id: 'DatabaseUID>DatabaseSN', localdata: [] }; var dataAdapter = new $.jqx.dataAdapter(sourceDatabases); // initialize jqxGrid $("#databaseGrid").jqxGrid({ width: '100%', theme: 'metro', source: dataAdapter, pageable: true, autoheight: true, sortable: true, altrows: true, enabletooltips: true, editable: true, rowdetails: true, filterable: true, selectionmode: 'multiplerows', columns: [ { text: 'ID', datafield: 'DatabaseSN', editable: false, width: '24%'}, { text: 'Name', datafield: 'DatabaseName', editable: false, width: '8%'}, { text: 'Description', datafield: 'Description', editable: false, width: '14%'}, { text: 'Creation time', datafield: 'CreationTime', cellsformat: 'dd/MM/yyyy HH:mm:ss', editable: false, width: '12%'}, { text: 'Last item update', datafield: 'LastItemUpdate', cellsformat: 'dd/MM/yyyy HH:mm:ss', editable: false, width: '12%'}, { text: 'Suite model', datafield: 'ModelVersionSN', editable: false, width: '24%'}, { text: 'Loaded', columntype: 'checkbox', datafield: 'Loaded', filterable: false, sortable: false, width: '6%'} ] }); $('#databaseGrid').on('rowselect', function (event) { var row = $('#databaseGrid').jqxGrid('getrowdatabyid', event.args.rowindex); rowsDatabaseSelected.add(row.HVerifyDatabaseSN); }); $('#databaseGrid').on('rowunselect', function (event) { var row = $('#databaseGrid').jqxGrid('getrowdatabyid', event.args.rowindex); rowsDatabaseSelected.delete(row.HVerifyDatabaseSN); }); } function updateDatabaseGrid() { $('#refreshDatabase').jqxButton({disabled: true }); $('#databaseGrid').jqxGrid('showloadelement'); function successfulDatabaseRequest(databases) { var newRowsIDList = []; for (var i = 0; i < databases.length; i++) { var dbID = databases[i].DatabaseUID.HVerifyDatabaseSN; newRowsIDList.push(dbID); databases[i]['Loaded'] = false; } var items = $("#databaseGrid").jqxGrid('getrows'); var itemsIDList = items.map(({HVerifyDatabaseSN})=>HVerifyDatabaseSN); if (!arraysEqual(itemsIDList, newRowsIDList)) { // to update sourceDatabases.localdata = databases; $("#databaseGrid").jqxGrid('updatebounddata'); var rows = $("#databaseGrid").jqxGrid('getrows'); for (var i = 0; i < rows.length; i++) { var row = rows[i]; if (rowsDatabaseSelected.has(row.HVerifyDatabaseSN)) { $('#databaseGrid').jqxGrid('selectrow', row.boundindex); } } } $('#refreshDatabase').jqxButton({disabled: false }); $('#databaseGrid').jqxGrid('hideloadelement'); } function failedlDatabaseRequest(err) { $('#refreshDatabase').jqxButton({disabled: false }); $('#databaseGrid').jqxGrid('hideloadelement'); } restRequest('GET', {}, successfulDatabaseRequest, ENDPOINT, failedlDatabaseRequest); } //#endregion //#region UTILS function restRequest(type, body, callbackSuccess, endpoint, callbackError) { $.ajax({ url: endpoint, type: type, contentType: 'application/json', data: JSON.stringify(body), success: function(data, status, options) { callbackSuccess(data); }, error: function (xhr, ajaxOptions, thrownError) { callbackError(thrownError); } }); } function arraysEqual(_arr1, _arr2) { if ( !Array.isArray(_arr1) || !Array.isArray(_arr2) || _arr1.length !== _arr2.length ) { return false; } const arr1 = _arr1.concat().sort(); const arr2 = _arr2.concat().sort(); for (let i = 0; i < arr1.length; i++) { if (arr1[i] !== arr2[i]) { return false; } } return true; } //#endregion
4) base.css
html, body { width: 100%; height: 100%; box-sizing: border-box; margin: 0; background-color:#E8E8EC; font-family:"Helvetica Neue", Helvetica, Arial, sans-serif; -webkit-touch-callout: none; -webkit-user-select: none; -moz-user-select: none; -ms-user-select: none; user-select: none; } #mainSplitter { border:none; } * { margin: 0; padding: 0; outline: none; border: none; -webkit-box-sizing: border-box; } *:before, *:after { -webkit-box-sizing: border-box; } .clearfix { *zoom: 1; } .clearfix:before, .clearfix:after { display: table; line-height: 0; content: ""; } .clearfix:after { clear: both; } .container { width:100%; padding:0; margin: 0 auto; } header { width: 100%; height: auto; background: #333; } .header-left { position: relative; color: white; } .header-right label{ position: absolute; top: -5em; right: 4em; cursor: pointer; } .header-right label span:before, .header-right label span:after{ content: ''; position: absolute; width: 2em; height: .5em; top: 4px; left: 0; background: #888D94; } .header-right label span:after{ top: 13px; } #open{ display: none; } .hidden-desktop{ display: none; } a { text-decoration: none !important; color: #888D94; } nav a { position: relative; display: flex; align-items: center; line-height: 35px; width:100%; -webkit-transition: all .3s ease; padding-bottom:0.3em; padding-top:0.3em; color: #888D94; border-left: 3px solid #333; } nav a p{ margin-bottom:0; margin-top:0; font-size:115%; font-weight:700; font-family:"Helvetica Neue", Helvetica, Arial, sans-serif; } nav a span{ width:20px; height:20px; margin-bottom:0; margin-top:0; font-size:140%; margin-left:1.8em; margin-right:0.9em; } nav a:hover { background-color:#333; color:#d9d9d9; } nav a:focus { outline: none; color: #888D94; } nav { background-color:#333; text-align:center; margin-top: 1em; } .header-right { position: relative; color: white; float: left; width: 70%; } #logo { text-align: center; cursor:pointer; } .suite { background-color:#1790d6; } #logo p{ width:100%; height:100%; margin:0; padding:1em; color:white; font-weight:bold; font-size:200%; font-family:"Helvetica Neue", Helvetica, Arial, sans-serif; } #logo span { margin-right:0.4em; } #logoName { width:100%; height:100%; margin:0; padding-top:1em; color:white; font-weight:bold; font-size:210%; font-family:"Helvetica Neue", Helvetica, Arial, sans-serif; } #logoVersion { width:100%; height:100%; margin:0; padding-top:-1em; padding-bottom:2em; padding-left:7em; color:white; font-size:80%; font-family:"Helvetica Neue", Helvetica, Arial, sans-serif; } #leftPanel { height:100%; padding-left:0; padding-right:0; background-color:#333; } .active { color:white !important; background-color:rgb(70, 70, 70); border-left: 3px solid white !important; } .freeSpace { background-color:#E8E8EC; height:160px; width:217px; position:absolute; top:113px; z-index:11; display:none; } .collapsedListContainer { float:none!important; top:113px; } #rightPanel { background-color:#E8E8EC; min-width:646px; overflow: hidden; position: relative; z-index: 0; } .clearfix:after { content: "."; display: block; height: 0; clear: both; visibility: hidden; } .clearfix { display: inline-block; } * html .clearfix { height: 1%; } /* Hides from IE-mac \*/ .clearfix { display: block; } .dataTables_scrollBody { overflow-x:hidden !important; overflow-y:hidden !important; } .widget-title { width:100%; color:#333; font-weight:bold; font-size:160%; font-family:"Helvetica Neue", Helvetica, Arial, sans-serif; text-align: center; } /* database section */ #database { padding: 26px 26px; padding-top: 2.8em; height:100%; display:none; } #databaseGridTitle { margin-top:1em; } #databaseButtons { display: flex; justify-content: left; align-items: center; border: none; margin-bottom:0.4em; }
I forgot to repeat an important thing: the error, even in the example above, occurs with a frequency of 10-15%.
So it is possible that, to generate the error, it is necessary to reload the page 10-20 timesHello EmilioP,
Thank you for this example and for the details.
Unfortunately, I still cannot reproduce it.
I need time to prepare the database if this is the reason.
But after many refreshes (more than 50th tries) I could not see the mentioned error.
I start the project with thehttp-server
server and after that click on the “Database” option on the left side.Best Regards,
thanks for trying.
The error happens to me at least once every 20 refreshes (more or less), both on chrome and on firefox.Could you write the ajax function you implemented?
Hello EmilioP,
I try to create one simple server via Node.js and below you could find the
app.js
file:var express = require("express"); var cors = require('cors') var app = express(); var PORT = 1771; var corsOptions = { origin: 'http://172.16.1.101:8081', optionsSuccessStatus: 200 // some legacy browsers (IE11, various SmartTVs) choke on 204 } app.get("/getdata", cors(corsOptions), (req, res, next) => { res.header('Access-Control-Allow-Origin', 'http://172.16.1.101:8081'); res.header('Access-Control-Allow-Credentials', true); res.header('Access-Control-Allow-Methods', 'GET,PUT,POST,DELETE'); res.header("Access-Control-Allow-Headers", "Origin, X-Requested-With, Content-Type, Accept"); next(); var jsonResult = "[" + "{" + "\"DatabaseUID\": {" + "\"DatabaseSN\": 1001" + "}," + "\"DatabaseName\": \"Test 1001\"," + "\"HVerifyDatabaseSN\": 0," + "\"Description\": \"First Test with #1001\"" + "}," + "{" + "\"DatabaseUID\": {" + "\"DatabaseSN\": 2002" + "}," + "\"DatabaseName\": \"Test 2002\"," + "\"HVerifyDatabaseSN\": 1," + "\"Description\": \"Second Test with #2002\"" + "}" + "]"; res.json(jsonResult); }); app.listen(PORT, () => { console.log("Server running on port " + PORT); });
About the
database.js
file I make small changes in therestRequest
function that you could check below:function restRequest(type, body, callbackSuccess, endpoint, callbackError) { $.ajax({ // var ENDPOINT = 'http://localhost:1771/getdata'; url: endpoint, type: type, // contentType: 'application/json', // data: JSON.stringify(body), crossDomain: true, xhrFields: { withCredentials: true }, crossDomain: true, success: function(data, status, options) { // callbackSuccess(data); callbackSuccess(JSON.parse(data)); }, error: function(xhr, ajaxOptions, thrownError) { callbackError(thrownError); } }); }
The project started on the
http-server
server.Best Regards,
https://www.jqwidgets.com -
