jQuery UI Widgets Forums Grid jqxgrid not displaying busy or loading indicator
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 11 years, 2 months ago.
  • alpesh
    I am using jqxgrid and I have below code snippet and i want to display load indicator on button click which calls the Ajax method and hide it on the success method or anyway other to display it as i need to show loading indicator from the time request made till i get the data
    $("#btnSearch").bind('click', function () {
            //show indicator here
            LoadLookUpSearchGrid();
        //Ajax call to fetch data
        function LoadLookUpSearchGrid() {
            var filterRows = getGridRows();
                type: 'POST',
                dataType: 'json',
                async: false,
                cache: false,
                url: 'AddEditView.aspx/LoadLookUpSearchGrid',
                data: JSON.stringify({
                    FilterType: $('select#ddlFilterType').val(),
                    SearchText: '',
                    FilterRows: filterGridRows
                contentType: 'application/json; charset=utf-8',
                success: function (data) {
                    var source = data.d;
                    SetSearchFields($('select#ddlFilterType option:selected').text(), source);
                error: function (err) {
                    alert(err.text + " : " + err.status);
        //source object to format data
        function SetSearchFields(fieldName, source) {
            var columns;
            if (fieldName == "Operating Company") {
                source = {
                    datatype: "xml",
                    datafields: [{
                        type: 'string'
                        type: 'string'
                    async: false,
                    root: "Company",
                    localdata: source
                columns = [{
                    text: 'OPCO ID',
                    dataField: 'COMPANY',
                    width: '30%'
                    text: 'Company Name',
                    dataField: 'DESCR',
                    width: '65%'
            lookupSearchResultGrid(source, columns, fieldName);
        //adaptor to fill source and bind grid
        function lookupSearchResultGrid(source, columns, fieldName) {
            var searchViewGridDataAdapter = new $.jqx.dataAdapter(source);
            $("#divLookupSearch").jqxGrid({
                width: '100%',
                source: searchViewGridDataAdapter,
                selectionmode: 'checkbox',
                columns: columns
            //hide indicator here on on success method of ajax call
    Could you please help us ?
    Thanks.
    Hello alpesh,
    On the click of the button call showloadelement and in the Ajax call success callback function call hideloadelement.
            $('#divLookupSearch').jqxGrid('showloadelement');
                    $('#jqxGrid').jqxGrid('hideloadelement');
