jQuery UI Widgets Forums Grid jqxgrid mastergrid perform using button click on each row
This topic contains 5 replies, has 2 voices, and was last updated by  Hristo 8 years, 2 months ago.
  • dan123
    Hi I used the sample master detail grid, and I am trying to figure out if there is a way to update the data source of the detail grid through using button click. I create a button column using the cellsrenderer, but I cannot seem to perform the similar function of the rowselect by using the button on each row.
    Here is my jsfiddle:
    https://jsfiddle.net/UbK74/426/
    dan123
    Could use help on this?
    Hello dan123,
    You want to when the click particular (custom) button to select the row. Could you clarify?
    dan123
    Yes hristo
    dan123
    Yes when I press the button for that row, it will bring the details for that row.
    Hello dan123,
    You could use selectrow method when clicking on the button (need to implement buttonclick callback of the column).
        <title id='Description'></title>
        <script type="text/javascript" src="../../jqwidgets/jqxnumberinput.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxinput.js"></script>
            $(document).ready(function ()
                var data = generatedata(200);
                    localdata: data,
                    datatype: "array",
                    datafields:
                        { name: 'price', type: 'number' }
                // initialize jqxGrid
                $("#jqxgrid").jqxGrid(
                    width: 850,
                    selectionmode: 'checkbox',
                      { text: 'First Name', datafield: 'firstname', width: 200 },
                      { text: 'Last Name', datafield: 'lastname', width: 200 },
                      { text: 'Product', datafield: 'productname', width: 190 },
                      { text: 'Quantity', datafield: 'quantity', width: 90, cellsalign: 'right' },
                      { text: 'Price', datafield: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' },
                          text: 'Edit', datafield: 'Edit', columntype: 'button', cellsrenderer: function ()
                              return "Edit";
                          }, buttonclick: function (row)
                              $('#jqxgrid').jqxGrid('selectrow', row);
        <div id='jqxWidget'>
            <div id="jqxgrid"></div>
    You need to decide how to proceed when having the second click on the button. Also, how to visualize the data in the Grid below.
