jQuery UI Widgets › Forums › Plugins › AngularJS › jqxGrid: groupsrenderer: place a link / button and propagate click events
Tagged: Angular, angular grid, click, directive, grid, group, groupable, groupsrenderer, jqxgrid, ng-click
This topic contains 2 replies, has 2 voices, and was last updated by badera 9 years, 8 months ago.
July 6, 2015 at 8:34 am jqxGrid: groupsrenderer: place a link / button and propagate click events #73376
Dear all
I have a jqxgrid with grouping and a groupsrenderer function. I need to be able to place a clickable ui element (e.g. a link or a button) inside the groups header. But how can I manage to bring the click event out to my scope – i.e. the scope, in which <jqx-grid> is placed? I tried different things:
1) $emit
Idea: Since the directive jqxgrid has its own scope, I should be able to fire an event to the parent scope (which is the scope containing the grid), catch the event an call my function.groupsrenderer: function (text, group, expanded) { return '<button ng-click="$emit(\'TEST\', \'test...\')">Activate</button>'; } ... $scope.$on("TEST", function(event, message) { alert("hallo " + message); });
However, this does not work. Why?
2) using own directive
groupsrenderer: function (text, group, expanded) { return '<my-directive></my-directive>'; }
According the example http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxangular/angularjs-datatable-custom-cell-template.htm, I tried to make my own directive and put it in the grouping header. But it seems, that this does not work; the directive template seems not to be evaluated / the DOM is not populated.
Can somebody help me on this? – I really need a solution.
Thanks in advance.
– baderaJuly 6, 2015 at 12:03 pm jqxGrid: groupsrenderer: place a link / button and propagate click events #73392Hello badera,
Please try this purely JavaScript solution:
<!DOCTYPE html> <html ng-app="demoApp"> <head> <link rel="stylesheet" type="text/css" href="../../jqwidgets/styles/jqx.base.css" /> <script type="text/javascript" src="../../scripts/angular.min.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.grouping.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript"> var demoApp = angular.module("demoApp", ["jqwidgets"]); demoApp.controller("demoController", function ($scope, $http) { $scope.createWidget = false; $http({ method: 'get', url: '../sampledata/beverages.txt' }).success(function (data, status) { // prepare the data var source = { datatype: "json", datafields: [ { name: 'name', type: 'string' }, { name: 'type', type: 'string' }, { name: 'calories', type: 'int' }, { name: 'totalfat', type: 'string' }, { name: 'protein', type: 'string' } ], id: 'id', localdata: data }; var dataAdapter = new $.jqx.dataAdapter(source); $scope.gridSettings = { width: 850, source: dataAdapter, columnsresize: true, groupable: true, groupsrenderer: function (text, group, expanded) { var message = 'user'; return '<button onclick="TEST(\'' + message + '\')">Activate</button>'; }, columns: [ { text: 'Name', datafield: 'name', width: 250 }, { text: 'Beverage Type', datafield: 'type', width: 250 }, { text: 'Calories', datafield: 'calories', width: 180 }, { text: 'Total Fat', datafield: 'totalfat', width: 120 }, { text: 'Protein', datafield: 'protein', minwidth: 120 } ] }; // now create the widget. $scope.createWidget = true; }).error(function (data, status) { // Some error occurred }); }); </script> </head> <body> <div ng-controller="demoController"> <jqx-grid jqx-create="createWidget" jqx-settings="gridSettings"> <script type="text/javascript"> function TEST(message) { alert('Hallo, ' + message + '.'); } </script> </jqx-grid> </div> </body> </html>
http://www.jqwidgets.com/July 6, 2015 at 12:17 pm jqxGrid: groupsrenderer: place a link / button and propagate click events #73395Thank you, Dimitar.
OK, this is the last possibility, if nothing else works. (But for sure not that nice…)
– badera -
