jQuery UI Widgets Forums Grid JqxGrid column menu closing issue
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years, 3 months ago.
  • JqxGrid column menu closing issue #98201
    ngc2
    I created custom filter menus for my jqxGrid and one of them has a datepicker. The issue is that the datepicker exceeds the height of the menu, so when you select a date it closes out the datepicker as well as the actual filter menu. Is there a way to get the filter menu to stay open?
    Thanks!
    JqxGrid column menu closing issue #98208
    Hello ngc2,
    You could use the columnmenuclosing: function (menu, datafield, height) {} callback of the Grid.
    With one boolean variable (flag) to return true in this callback if you want to close it and false if you do not.
