jQuery UI Widgets Forums Grid jqxGrid auto column width with jqWidgets 3.0.3
This topic contains 8 replies, has 4 voices, and was last updated by  ae50042 8 years, 6 months ago.
  • harsh
    I have replaced jqWidgets 3.0.3 with older one in our application. While doing unit testing found below problems,
    1. Style is not available in this version.
      .jqx-grid-cleared-cell {
      visibility: hidden;
    2. In jqxGrid we have given grid width to ‘100%’. Here columns are not auto fitting with screen.
    var grid = this.gridParentElement.jqxGrid({
    source : sourceData,
    width: ‘100%’,
    height : ‘100%’,….
    Also I have tried with width:’auto’ property of column.
    Note: The same code is working fine with older version i.e. 2.8.
    Thanks in advance,
    Harsh
    Hi Harsh,
    We never supported width: ‘auto’ setting. The .jqx-grid-cleared-cell style is applied only when it is necessary and is applied correctly in ver. 3.0.3.
    harsh
    1. visibility:’hidden’ property of ‘.jqx-grid-cleared-cell’ is available in lower version of jqx.base.css but not in 3.0.3.
    2. Columns are not fitting in grid area even if we keep width:” property of column.
    Harsh
    Hi Harsh,
    – Most probably that setting is removed because it is not necessary.
    – width is expected to be set to a number or percentage. Other settings are not supported.
    harsh
    If I have 3 columns and I have added width “25%” to first two columns and third will be default i.e. I haven’t added width property to it.
    Then in this case what would be the width for last column?
    Harsh
    Hi Harsh,
    Please, try that sample:
    <title id='Description'>This example shows how to create a Grid from Array data.</title>
    var data = new Array();
    var firstNames =
    var lastNames =
    var productNames =
    var priceValues =
    for (var i = 0; i < 200; i++) {
    var row = {};
    row["price"] = price;
    row["quantity"] = quantity;
    data[i] = row;
    localdata: data,
    datatype: "array",
    datafields:
    $("#jqxgrid").jqxGrid(
    width: 670,
    { text: 'Name', dataField: 'firstname', width: '25%' },
    { text: 'Last Name', dataField: 'lastname', width: '25%' },
    { text: 'Total', dataField: 'total', cellsalign: 'right', cellsformat: 'c2' }
    <div id='jqxWidget'>
    <div id="jqxgrid">
    panky
    If I keep width: ‘100%’, instead of width: 670, then I have to mention width of each column in %, otherwise
    it shows blank column at the end.
    I m using v 3.0.4.
    Panky
    Hi Panky,
    If you want your last column to fill the remaining space, do not set its “width”.
    ae50042
    Hi ok, if I don’t put width at the last columns, the grid is not layout responsive:
    When I make the browser window smaller, I will able to see just few px of the last column also if I try to scroll horizontal.
    Ho can I fix that?
    Giorgio.
