jQuery UI Widgets › Forums › Grid › jqxGrid add empty row problem with dropdownlist column
Tagged: add row, dropdownlist column, edit row, jqxGrid ;, row
This topic contains 3 replies, has 2 voices, and was last updated by Stanislav 7 years, 2 months ago.
I have a jqxgrid with a dropdownlist column. When I add empty rows, the first row is well displayed. When I enter a new row and leave the edit mode, the first row disappears.
Code :
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="jquery/jquery.min.js"></script> <script type="text/javascript" src="jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="jqwidgets/jqxcombobox.js"></script> <script type="text/javascript" src="jqwidgets/jqxpanel.js"></script> <script type="text/javascript"> $(document).ready(function () { var dataEdited = new Array(); var sourceList = { datatype: "json", datafields: [ { name: 't_id', type: 'int' }, { name: 't_libelle', type: 'string' } ], id: 't_id', url: "sampledata/listdata.json" }; var dataAdapterList = new $.jqx.dataAdapter(sourceList, { autoBind: true }); var sourceGrid = { datatype: "json", datafields: [ { name: 'fiche_id', type: 'int' }, { name: 'fiche_num', type: 'string' }, { name: 'fiche_libelle', type: 'string' }, { name: 'type_id', type: 'int' }, { name: 'type_libelle', value: 'type_id', values: { source: dataAdapterList.records, value: 't_id', name: 't_libelle' } } ], id: 'fiche_id', url: "sampledata/griddata.json", updaterow: function (rowid, rowData, commit) { dataEdited.push(rowData); commit(true); } }; var dataAdapterGrid = new $.jqx.dataAdapter(sourceGrid); $("#jqxgrid").jqxGrid( { width: 700, height: '100%', source: dataAdapterGrid, autoheight: false, sortable: true, altrows: true, enabletooltips: true, editable: true, selectionmode: 'singlerow', editmode: 'selectedrow', showfilterrow: true, filterable: true, columns: [ { text: 'idfiche', datafield: 'fiche_id', cellsalign: 'center', hidden: true, editable: false }, { text: 'Type fiche', datafield: 'type_id', displayfield: 'type_libelle', cellsalign: 'left', width: 250, columntype: 'dropdownlist', createeditor: function (row, cellvalue, editor) { editor.jqxDropDownList({ source: dataAdapterList, displayMember: 't_libelle', valueMember: 't_id', autoDropDownHeight: true }); } }, { text: 'Numero fiche', datafield: 'fiche_num', cellsalign: 'center', width: 100 }, { text: 'Libelle fiche', datafield: 'fiche_libelle', cellsalign: 'left', width: 350 } ] }); $("#addRow").click(function () { $("#jqxgrid").jqxGrid('addrow', null, {}, 'first'); }); }); </script> </head> <body class='default'> <div id='jqxWidget' style="font-size: 13px; font-family: Verdana; float: left;"> <div id="jqxgrid"> </div> <br /> <button id="addRow"> Add row</button> </div> </body> </html>
sampledata/listdata.json :
[{"t_id":1,"t_libelle":"type 1"},{"t_id":2,"t_libelle":"type 2"},{"t_id":3,"t_libelle":"type 3"}]
sampledata/griddata.json :
[{"fiche_id":1,"fiche_num":"FIC-0001","fiche_libelle":"TEST1","type_id":1,"type_libelle":"type 1"}]
I would like to be able to add rows without them disappearing.
Can you help me please ?Hello Yannx02,
Ok, I managed to simulate your case with custom data.
You are right, when you create a row it is fine, but when you create a second row the first one creates a duplicate, which disappears not the initial row itself.
At least this is what I saw in my tests. Non the less, this shouldn’t be happening, and I am very thankful to you for giving us this example!But when I test a simple example, like the one on our website, it works fine, and no rows are duplicated/deleted.
I will continue to test your example, And I will try to give you an update soon. I would advise you to do the same if possible.Best Regards,
StanislavjQWidgets Team
http://www.jqwidgets.com/Hello Stanislav,
The problem does not occur with text columns
The problem occurs as soon as we add a dropdowlist column.
I will continue to test on my side as well.Best Regards,
Yannx02
Hello Yannx02,
Thank you for the update!
We appreciate your help.Best Regards,
