jQuery UI Widgets Forums Lists DropDownList jqxDropDownList initial selection with json using selectItem
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years, 9 months ago.
  • Weibing
    I’m trying to select a specific item in the dropdown on loadcomplete, however, the dropdown populates, but doesn’t initially select anything. Can anyone point me in the right direction. Much appreciated.
    var pltcSessionDropDown = function(){
    var pltcSessions =
    datafields:
    { name: ‘pltc_session_id’, type: ‘string’ },
    { name: ‘pltc_session_nm’, type: ‘string’ }
    url: ‘includes/reports.cfc?method=pltcSessions’
    var sessionDataAdapter = new $.jqx.dataAdapter(pltcSessions,
    loadComplete: function () {
    $(“#myDropDown”).jqxDropDownList(‘selectItem’, ‘1709’);
    return sessionDataAdapter
    var dataAdapter = pltcSessionDropDown();
    $(“#myDropDown”).jqxDropDownList({source: dataAdapter, displayMember: “pltc_session_nm”, valueMember: “pltc_session_id”, theme:’bootstrap’});
    Hello Weibing,
    Do you receive any error message in the console?
    If you know the exact index of the item you could use selectedIndex property.
    Also, if this does not help you could get all items with var items = $("#jqxDropDownList").jqxDropDownList('getItems'); and with iteration to select desired item with “selectIndex” method.
