jQuery UI Widgets Forums Lists DropDownList jqxDropdownlist custom rendering issue
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 8 years, 10 months ago.
  • magostoni
    Actually I’m using a jqxDropDownList widgets, loading data from a service written in php that send back JSON data.
    these are the json data returned back by Produzione_materiali/get_elenco_materiali service:
    [{"TotalRows":"6","Rows":[{"codmateriale":"ALLUMINIO","unita":"PZ","prezzo":"0.00000"},{"codmateriale":"FERRO","unita":"PZ","prezzo":"0.00000"},{"codmateriale":"LEGNO","unita":"PZ","prezzo":"0.00000"},{"codmateriale":"OTTONE","unita":"PZ","prezzo":"0.00000"},{"codmateriale":"PLASTICA","unita":"PZ","prezzo":"0.00000"},{"codmateriale":"ZAMA","unita":"KG","prezzo":"2.25000"}]}]
    This is the javascript code to display jqwidget:
                    { name: 'codmateriale' },
                    { name: 'unita' }
                url: '<?php echo site_url("/Produzione_materiali/get_elenco_materiali/");?>',
                root: 'Rows',
                async: false
            $("#materiale").jqxDropDownList({
                source: dataAdapter, displayMember: "codmateriale", valueMember: "codmateriale", width: '100%', height: 25
    What I would need, is to show in the dropdown something like “codmateriale” + “[” + unita + “]”
    I would like to use custom rendering but I was not able to figure out how to get the 2 fields:
                    var datarecord = source[index];
                    var text = source.codmateriale + "[" + source.unita + "]"
                    return text;
    Could someone help me?
    Matt
    Hello Matt,
    Here is how to achieve your requirement:
                var data = [{
                    "TotalRows": "6",
                    "Rows": [{
                        "codmateriale": "ALLUMINIO",
                        "unita": "PZ",
                        "prezzo": "0.00000"
                        "codmateriale": "FERRO",
                        "unita": "PZ",
                        "prezzo": "0.00000"
                        "codmateriale": "LEGNO",
                        "unita": "PZ",
                        "prezzo": "0.00000"
                        "codmateriale": "OTTONE",
                        "unita": "PZ",
                        "prezzo": "0.00000"
                        "codmateriale": "PLASTICA",
                        "unita": "PZ",
                        "prezzo": "0.00000"
                        "codmateriale": "ZAMA",
                        "unita": "KG",
                        "prezzo": "2.25000"
                var source = {
                    datafields: [{
                    localdata: data,
                    root: 'Rows',
                    async: false
                    width: '100%',
                    height: 25,
                        var datarecord = dataAdapter.records[index];
                        var text = datarecord.codmateriale + "[" + datarecord.unita + "]";
                        return text;
    <body>
        <div id='materiale'>
