jQuery UI Widgets Forums Grid jqxDropDownButton Grid Popup Model dialog issue
This topic contains 3 replies, has 2 voices, and was last updated by  panky 10 years, 9 months ago.
  • panky
    Hi
    I have jqxDropDownButton with JQXGrid on model popup window [Jquery UI].
    I have only filtering enabled, not paging.
    When I enable filter on grid,
    $(“#jqxgrid” + id).jqxGrid({ filterable: true, showfilterrow: true, autoshowfiltericon: true });
    it does not filter grid, but same works fine when my jqxDropDownButton is on page.
    Is there any way for this ? Can someone help me how to find out cause for filtering not working?
    If I enable paging , I don’t see pager at the bottom of the Grid.
    I am using v 3.4.0.
    Panky
    Hi Panky,
    You can use jqxWindow instead and you won’t experience such issue. The UI Dialog prevents some inputs when it is opened.
    panky
    Thanks Peter !!
    I used JQXwindow and it worked fine, only I did extra work to style JQXWindow to match my application styling.
    Thanks again !!
    Panky
    panky
    Today I came across issue. When I use JQXWindow with jqxDropDownButton control, after couple of uses Div which I am using for
    model popup, does not contain in DOM. And I get error
    Uncaught Error: Invalid jQuery Selector – #CopyContainer! Please, check whether the used ID or CSS Class name is correct.
    Is there any thoughts?
    Panky
