jQuery UI Widgets Forums Plugins Data Adapter jqxDataAdapter and updaterow method
This topic contains 5 replies, has 2 voices, and was last updated by  Hristo 8 years, 6 months ago.
  • jqxDataAdapter and updaterow method #88110
    Maurizio0015
    I have four simple objects: a source, a jqxDataAdapter, a jqxInput and a jqxButton.
    The source, through a call, fills a jqxInput.
    After changing the value of the jqxInput and press the ‘Update’ button, i want to be called the method ‘updaterow’ of my source.
    How can I do?
    This is my code:
            var row = {};
            row["Id"] = 3055;
            var getdescription = "@GetDescription";
            var updatedescription = "@UpdateDescription";
                 { name: 'id', type: 'int' },
                 { name: 'descrizione', type: 'string' }
            url: getdescription,
            async: false,
                rowdata.Id = rowid;
                    dataType: 'json',
                    cache: false,
                    data: rowdata,
                    url: updatedescription,
                    type: "POST",
                        commit(true);
                        alert(jqXHR.statusText);
                        commit(false);
            adapter.dataBind();
            $("#jqxId").jqxInput();
            $("#jqxDescrizione").jqxInput();
            $("#jqxId").jqxInput('val', adapter.records[0].id);
            $("#jqxDescrizione").jqxInput('val', adapter.records[0].descrizione);
            $("#jqxUpdate").jqxButton();
            $("#jqxUpdate").bind('click', function () {
                row["Id"] = 3055;
                row["Descrizione"] = $("#jqxDescrizione").val();
                //How can i call the 'updaterow' method of my source, here?
    jqxDataAdapter and updaterow method #88140
    Hello Maurizio0015,
    This ‘updaterow’ member is part of the source of others Widgets.
    I would like to suggest demo that could be useful:
    http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxinput/remoteautocomplete.htm?light
    Also this example, there you could find way to control the typed data in the Input:
    http://jsfiddle.net/jqwidgets/BcYMU/
    jqxDataAdapter and updaterow method #88150
    Maurizio0015
    Hi Hristo,
    i do not want to check the input data, but proceed to storing them on my database.
    I solved by eliminating the ‘updaterow’ method from the source and entering the ajax call in the point of my interest, as shown here:
                row["Id"] = 3055;
                row.Id = 3055;
                    dataType: 'json',
                    cache: false,
                    data: row,
                    type: "POST",
                        commit(true);
                        commit(false);
    I wanted to ask you if you want to extend the jqxDataAdapter object so that it can contain within itself the ability to recall the three classic CRUD methods that may contain the source (‘addrow’, ‘updaterow’, ‘deleterow’).
    In this way, any jqWidgets object may have a source not only in reading, but also in the modification and deletion, delegating to jqxDataAdapter the opportunity to call them.
    Could you give me more information about this?
    Maurizio.
    jqxDataAdapter and updaterow method #88176
    Hello Maurizio,
    We have many other options to communicate with the server.
    (You could take a look at those members – processData, formatData, beforeSend, loadServerData)
    You could use AJAX for different queries.
    Also, I would like to suggest you this example:
    http://www.jqwidgets.com/jquery-widgets-demo/demos/php/login_form.htm?light
    jqxDataAdapter and updaterow method #88192
    Maurizio0015
    Hi Hristo,
    i thank you for your interest.
    I think the jqxDataAdapter is not necessary for my purpose.
    I can define two AJAX functions: one for data loading and one for their updateing, and remove the jqxDataAdapter whose true function is to interface more complex objects such as jqxGrid.
    I understood correctly?
    Maurizio.
    jqxDataAdapter and updaterow method #88232
    Hello Maurizio,
    Yes, this is what I mean.
    Thank you for your understanding.
