jQuery UI Widgets › Forums › Lists › ComboBox › jqxcombobox combobox issue for .NET MVC VS2010
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 11 years, 10 months ago.
I am running to an issue when I try to use this tool JS widger Combobox.
I have added all the necessary JS script file in my .net Razor code but whenever I ran the
site it always gives me an err Line: 7
Error: ‘jqx’ is null or not an objectI commented out the script below and my code started to run but no data on combobox
<scriptsrc=”@Url.Content(“../../Scripts/JQwidgets/jqxbuttons.js”)”type=”text/javascript”></
I think the culprit to this issue is the jqxbuttons.JS.. I copied the sample HTM file bindingtojson.htm inside my project file and have no issue running it but on .net MVC Razor it always show an error of Line: 7
Error: ‘jqx’ is null or not an objectThanks!
snippet of my code
ViewBag.Title = “Index”;
Layout = null;
<script src=”@Url.Content(“~/Scripts/JQwidgets/gettheme.js”)” type=”text/javascript”></script>
<script src=”@Url.Content(“../../Scripts/JQwidgets/jqxbuttons.js”)” type=”text/javascript”></script>
<script src=”@Url.Content(“~/Scripts/JQwidgets/jqxcore.js”)” type=”text/javascript”></script>
<script src=”@Url.Content(“~/Scripts/JQwidgets/jqxdata.js”)” type=”text/javascript”></script>
<script src=”@Url.Content(“~/Scripts/JQwidgets/jqxscrollbar.js”)” type=”text/javascript”></script>
<script src=”@Url.Content(“~/Scripts/JQwidgets/jqxcombobox.js”)” type=”text/javascript”></script>
<script src=”@Url.Content(“~/Scripts/JQwidgets/jqxlistbox.js”)” type=”text/javascript”></script>
<h2>
Index</h2>
<div id=’jqxWidget’>
<div style=”font-size: 12px; font-family: Verdana;” id=”selectionlog”></div>
var theme = getDemoTheme();var url = “customers.txt”;
{ name: ‘CompanyName’ },
{ name: ‘ContactName’ }
url: url,
async: false
var dataAdapter = new $.jqx.dataAdapter(source);// Create a jqxComboBox
$(“#jqxWidget”).jqxComboBox({ selectedIndex: 0, source: dataAdapter, displayMember: “ContactName”, valueMember: “CompanyName”, width: 200, height: 25, theme: theme });// trigger the select event.
$(“#jqxWidget”).on(‘select’, function (event) {
if (event.args) {
var item = event.args.item;
if (item) {
var valueelement = $(“<div></div>”);
valueelement.text(“Value: ” + item.value);
var labelelement = $(“<div></div>”);
labelelement.text(“Label: ” + item.label);$(“#selectionlog”).children().remove();
$(“#selectionlog”).append(labelelement);
$(“#selectionlog”).append(valueelement);
Thanks for writing.
1. getDemoTheme() is a function used in our Online samples. That is the reason it is called getDemoTheme. That should not be used when using jQWidgets. For setting a theme, you may take a look at the Styling and Appearance help documentation topics available on our web site.
2. jqxbuttons.js is loaded before jqxcore.js. That is not correct because jqxbutton.js uses jqxcore.js. The same is valid for the jqxcombobox.js and jqxlistbox.js.
3. Please, take a look at (4.) in this help topic: http://www.jqwidgets.com/jquery-widgets-documentation/documentation/asp.net-integration/asp.net-grid-server-side-editing.htm. It shows how to add references to the jQWidgets JavaScript files in MVC3 Application.Best Regards,
