jQuery UI Widgets › Forums › Gauges and Maps › Gauges › jqxBarGauge too small?
This topic contains 4 replies, has 2 voices, and was last updated by Todor 6 years ago.
AuthorjqxBarGauge too small? Posts
I am following the example for a simple jqxguage but when I run the sample the “dial” portion is microscopic in size. It is being loaded via AJAX into a div and inspection of the widget/canvas looks like THAT is big enough but the gauge is still tiny.
My code is:<head> <title id='Description'>Dashboard</title> <link rel="stylesheet" href="css/font-awesome.css" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.bootstrap.css" > <link rel="stylesheet" href="jqwidgets/styles/jqx.arctic.css" type="text/css" /> <script type="text/javascript" src="jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="jqwidgets/jqxdraw.js"></script> <script type="text/javascript" src="jqwidgets/jqxchart.core.js"></script> <script type="text/javascript" src="jqwidgets/jqxchart.annotations.js"></script> <script type="text/javascript" src="jqwidgets/jqxchart.api.js"></script> <script type="text/javascript" src="jqwidgets/jqxbargauge.js"></script> <script type="text/javascript" src="jqwidgets/globalization/globalize.js"></script> <script type="text/javascript" src="jqwidgets/demos.js"></script> <script type="text/javascript"> $(document).ready(function () { $('#barGauge').jqxBarGauge({ colorScheme: "scheme02", width: getWidth('barGauge'), height: getHeight('barGauge'), values: [102, 115, 130, 137], max: 150, tooltip: { visible: true, formatFunction: function (value) { var realVal = parseInt(value); return ('Year: 2019<br/>Price Index:' + realVal); }, } }); }); </script> </head> <body> <div class="row text-center"> <div class="col-md-12"> <h1>Dashboard</h1> </div> </div> <div class="row"> <div class="col-md-6"> <div id="barGauge"></div> </div> </div> </body>
Pic is here: https://imgur.com/a/wOnLlBT
Have i hit a limit on question asked and answered during evaluation ?
Hello robf,
I would like to suggest comment out these two rows – width: getWidth(‘barGauge’) and height: getHeight(‘barGauge’).
TodorjQWidgets Team
https://www.jqwidgets.comHmm. Unfortunately there was no change. FYI: I use this feature with other, successfully rendered, widgets – e.g. grid, so it doesn’t appear to be a jquery compatibility issue. I am using jquery 3.3.1.
Hello robf,
Please, share a jsfiddle/codepen example with your code which demonstrates the issue then we would be able to properly investigate it.
TodorjQWidgets Team
https://www.jqwidgets.com -
