jQuery UI Widgets Forums Plugins AngularJS jqx-grid: ng-click in cellsrenderer
This topic contains 3 replies, has 3 voices, and was last updated by  Peter Stoev 10 years, 2 months ago.
  • jqx-grid: ng-click in cellsrenderer #64571
    badera
    Dear all
    I would like to use the cellsrenderer function to get customized content in the grid cells and some of the elements should be clickable i.e. bound with ng-click to a scope function:
                $scope.myfunction = function() {
                    // do something
                var cellsrenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
                        return '<span ng-click="myfunction()">mylink</span>;
                $scope.gridSettings = {
                    source: source,
                      { text: 'Last Name', datafield: 'lastname', width: 100, cellsrenderer: cellsrenderer }
    However, it does not seem to execute the ng-click. Why?
    Thanks in advance for your help!
    jqx-grid: ng-click in cellsrenderer #64580
    Hi badera,
    cellsrenderer can be used only for displaying HTML in the cells. You can’t use the function to handle clicks, create widgets, etc.
    jqx-grid: ng-click in cellsrenderer #65490
    akshatn
    This is not good.
    You should at least provide a gateway from the jqxGrid so the caller can execute a function.
    akshat
    jqx-grid: ng-click in cellsrenderer #65492
    Hi Akshat,
    cellsrenderer works in the way we designed it. At present, we do not plan any changes about it.
