Hello bwalsh429,
I would suggest you use some worked example (reuse it) to create your new one.
About how to import references paths:
– Go on to the menu (in upper-left side) there has 'File' | "Project" | 'Share' | 'My Account'
– From “Project” choose "Libraries"
and there add needed references.
Hint: It is important before you send the example to someone to make it visible.
To do this you should navigate to “Share” menu and switch on 'Everyone'
option and save it again.
