jQuery UI Widgets › Forums › Grid › Issues with FilterRow example
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 11 years ago.
I’m a newb to jqwidgets and my knowledge of jquery is very basic.
I am having a problem getting JQWGrid to work properly. I’m trying to implement the “Filter Row” example, modified to use my own datasource.
It’s mostly working, but I’m having several issues:
A bunch of my fields are dates, which instead of displaying as dates, show as [Object object]: http://gardencalc.drivingpeace.com/grid.htm
I’ve also set up filters on each column, but I can’t actually select anything from the checkboxes. Not sure why that is.Also, is it possible to NOT have filters for the dates? I really only want the checkbox filters on the first 3 columns.
I’m pulling data out of mySQL using PHP. Here’s my raw data:
http://gardencalc.drivingpeace.com/grid_data.phpHere’s the source code for the “grid.htm” file:
<`!DOCTYPE html>
<html lang=”en”>
<title id=’Description’>In this example is demonstrated how to bind jqxGrid to MySQL Database.</title>
<link rel=”stylesheet” href=”css/jqx/jqx.base.css” />
<script type=”text/javascript” src=”js/jqx/jquery-1.10.2.min.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxcore.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxdata.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxbuttons.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxlistbox.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxdropdownlist.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxmenu.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxgrid.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxgrid.filter.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxgrid.sort.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxgrid.selection.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxpanel.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxcalendar.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxdatetimeinput.js”></script>
<script type=”text/javascript” src=”js/jqx/jqxcheckbox.js”></script>
<script type=”text/javascript” src=”js/jqx/globalize.js”></script>
$(document).ready(function () {var source =
{ name: ‘Type’, type: ‘string’},
{ name: ‘Method’, type: ‘string’},
{ name: ‘Crop’, type: ‘string’},
{ name: ‘SowDirect’, type: ‘date’},
{ name: ‘SowTransplant’, type: ‘date’},
{ name: ‘Transplant’, type: ‘date’},
{ name: ‘BeginHarvest’, type: ‘date’},
{ name: ‘EndHarvest’, type: ‘date’}
url: ‘grid_data.php’,
cache: false
};var dataAdapter = new $.jqx.dataAdapter(source);
$(“#jqxgrid”).jqxGrid(
width: 820,
source: source,
showfilterrow: true,
selectionmode: ‘multiplecellsextended’,columns: [
{ text: ‘Type’, filtertype: ‘checkedlist’, datafield: ‘Type’, width: 100},
{ text: ‘Method’, filtertype: ‘checkedlist’, datafield: ‘Method’, width: 100 },
{ text: ‘Crop’, filtertype: ‘checkedlist’, datafield: ‘Crop’, width: 100 },
{ text: ‘Sow Direct’, datafield: ‘SowDirect’, filtertype: ‘date’, width: 100, cellsalign: ‘right’, cellsformat: ‘d’ },
{ text: ‘Sow Transplant’, datafield: ‘SowTransplant’, filtertype: ‘date’, width: 100, cellsalign: ‘right’, cellsformat: ‘d’ },
{ text: ‘Transplant’, datafield: ‘Transplant’, filtertype: ‘date’, width: 100, cellsalign: ‘right’, cellsformat: ‘d’ },
{ text: ‘Begin Harvest’, datafield: ‘BeginHarvest’, filtertype: ‘date’, width: 100, cellsalign: ‘right’, cellsformat: ‘d’ },
{ text: ‘End Harvest’, datafield: ‘EndHarvest’, filtertype: ‘date’, width: 100, cellsalign: ‘right’, cellsformat: ‘d’ }
$(‘#clearfilteringbutton’).jqxButton({ height: 25});
$(‘#clearfilteringbutton’).click(function () {
$(“#jqxgrid”).jqxGrid(‘clearfilters’);
<body class=’default’>
<div id=”jqxgrid”></div>
<input style=”margin-top: 10px;” value=”Remove Filter” id=”clearfilteringbutton” type=”button” />
</html>`Any suggestions would be welcome.
Thanks!
Hi gweber,
Actually, you are asking that for a 2nd time. The response would be the same.
That happens because the Dates in your data source are stored in this way: {“date”:”2014-05-26 00:00:00″,”timezone_type”:3,”timezone”:”America\/Los_Angeles”} i.e the Date is actually an Object.I think that the following: { name: ‘EndHarvest’, type: ‘date’} should be { name: ‘EndHarvest’, map: ‘EndHarvest>date’, type: ‘date’}
Peter StoevThank you Peter, that did the trick.
Can you also tell me why I can’t select anything from the checkbox filters on the first 3 columns?
And how do I NOT display filters for the date fields? I only want the checkbox filters on the first 3 columns.
Thank you!
Hi gweber,
1. The Images used by our Themes are missing on your side. I suppose that you did not add the folder. That’s the reason you will not see the Calendar Icon, the CheckBox checks which are images, etc.
2. To disable the Filters of some columns, set their “filterable” property to false.Best Regards,
