jQuery UI Widgets Forums Grid Issue with interactive Tables
This topic contains 8 replies, has 2 voices, and was last updated by  Glen 11 years, 8 months ago.
  • Issue with interactive Tables #26691
    Glen
    I have an issue with implimenting below functionality.
    I have two tables developed using JQwidgets
    1. When I select a value from first table(Say Employee ID)
    2.All the values corresponding to that field(in our example -employee ID) , should be filtered out in the second table.
    I’m stuck up with this issue.Any tips in resolving this issue will be appreciated.
    Thanks in advance.
    Issue with interactive Tables #26693
    Hello Toms,
    Please check out the demo Master-Details. We hope it is helpful to you.
    Issue with interactive Tables #26740
    Glen
    Thanks a ton Dimitar . I was really stuck up with this issue. I could able to perform this functionality now.
    Is’t possible to do below functionality using jqwidgets ?.
    In the example you have provided.When i click on a row , corresponding related records will be shown in second table.
    Now my implimentation is..If i filter out some record in first table , corresponding related records should be showed in second table.Any pointers or clue on implimenting this functionality
    Issue with interactive Tables #26759
    Glen
    To get the column name of filtered record , we can use the below code
    var filterinfo = $(“#jqxgrid”).jqxGrid(‘getfilterinformation’);
    var eventData = “Triggered ‘filter’ event”;
    for (i = 0; i < filterinfo.length; i++) {
    var eventData = "Filter Column: " + filterinfo[i].filtercolumntext;
    alert(eventData)
    But how to get filtered out values in an array.
    for eg : I have following values in an array {a,a,y,a,a,k,s}.
    I have filtered out all the ‘a’ s . How to get these filtered out values(in this case {a,a,a,a}) in an array ( var data=new Array();)
    Thamks in advace
    Issue with interactive Tables #26779
    Hi Toms,
    Here is how to get the filter values:
    var filterinfo = $("#jqxgrid").jqxGrid("getfilterinformation");
    var filters = filterinfo[0].filter.getfilters();
    The filters variable is an array of objects. Each object contains the properties value, condition, operator and type.
    Issue with interactive Tables #26979
    Glen
    Thanks for the response Dimitar .
    But my issue is how to get the filetred out values in an array .
    Using var filters = filterinfo[0].filter.getfilters(); , we can get value, condition, operator and type.
    But what i need is filtred out values. eg if localdata: {a,a,a,b,c,a} has following values and I have filtered the data using the criteria
    filter= a . So my grid\table will sho up all the filtered values (in our example {a,a,a,a}).
    So how to get this values in an array.
    For rowselect( $(“#jqxgrid”).on(‘rowselect’, function (event) {) ,
    , we can get the values like
    var cis = event.args.row. . Similarly After filtering out the grids , I need to retieved the filtered values like this in an array({a,a,a,a})).
    I’m really stuck up with issue.Any help will be appreciated
    Issue with interactive Tables #27060
    Glen
    The real issue is , when I apply filter in first table…values corresponding to filtered out row should be shown in second table .
    Master-Details example was helpful in doing the same functionality while a row is selected.
    But my issue is I have to implement the same functionality when a column is filtered out.
    Issue with interactive Tables #27080
    Hi Toms,
    Please use the method getdisplayrows. Here is more information about it from the API Documentation:
    Gets all rows that are currently displayed in the Grid. The method returns an Array of the displayed rows. The Grid’s sorting, filtering, grouping and paging will affect the result of this method.
    Code example
    Invoke the getdisplayrows method.
    // gets all rows loaded from the data source.
    var rows = $(‘#jqxGrid’).jqxGrid(‘getdisplayrows’);
    // gets the first displayed row.
    var rowData = rows[0];
    // gets the ID of the first displayed row.
    var rowID = rowData.uid;
    // gets the bound index of the first displayed row. The bound index is the row’s index in the array returned by the “getboundrows” method.
    var boundIndex = rowdData.boundindex;
    Issue with interactive Tables #27121
    Glen
    Wow .This is what exactly I was looking for.I tested and it works perfectly
    Dimitar , thanks a ton buddy :).
