jQuery UI Widgets › Forums › Grid › Issue with Grid width
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 12 years, 8 months ago.
AuthorIssue with Grid width Posts
I have a modal window with Two Tabs.
In the first Tab, I have a Grid inside.
The modal window opens on a normal button click.
Issue: The grid width shrinks to half of the window width and when I double click any of the columns in the Grid, it get expanded to full size.Could you tell me why I am facing this issue?
My initialization for Window, Tabs and Grid is as below.
$('#objectModelWindow').jqxWindow({ maxHeight: 1250, maxWidth:5500, minHeight: 750, minWidth: 850, height: document.documentElement.clientHeight-90, width: document.documentElement.clientWidth-100, theme: theme, resizable: false, isModal: true, modalOpacity: 0.3, position: { x: 70, y: 70 }, autoOpen: false }); $('#tab1').jqxTabs({width:'100%', height: '30%', theme: theme }); $('#tab2').jqxTabs({width:'100%', height: '80%',theme: theme });$("#jqxgridDR").jqxGrid( { width: '100%', //columnsmenuwidth: '100%', source: reqDataAdapter, editable: true, pageable: true, editmode: 'dblclick', autoheight: true, //columnsresize: true, altrows:true, filterable: true, sortable: true, selectionmode: 'singlecell', columns: [ { text: 'name', datafield: 'name', columntype: 'textbox', width: 100, pinned: true, editable: false } ] }); // change columns collection. Requirments $("#jqxgridDR").jqxGrid({ columns: reqGridColumns });
Hi DollyB,
The provided source code about the datagrid and tabs does not help much. Please post a full sample or send it to support@jqwidgets.com so we can try your scenario locally.
Sent the code sample through mail.
Thankx
DollyB.Hi DollyB,
Here is an example based on your source code. Note that the first tab has its initTabContent property set. It is used for integration of other widgets in jqxTabs.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head> <title></title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../scripts/jquery-1.7.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxwindow.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtabs.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.grouping.js"></script> <script type="text/javascript" src="../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript"> $(document).ready(function () { var initGrid = function () { var url = "beverages.txt"; // prepare the data var source = { datatype: "json", datafields: [ { name: 'name' }, { name: 'type' }, { name: 'calories' }, { name: 'totalfat' }, { name: 'protein' }, ], id: 'id', url: url }; var dataAdapter = new $.jqx.dataAdapter(source, { downloadComplete: function (data, status, xhr) { }, loadComplete: function (data) { }, loadError: function (xhr, status, error) { } }); $("#jqxgridDR").jqxGrid( { width: '100%', //columnsmenuwidth: '100%', source: dataAdapter, editable: true, pageable: true, editmode: 'dblclick', autoheight: true, //columnsresize: true, altrows: true, filterable: true, sortable: true, selectionmode: 'singlecell', columns: [ { text: 'Name', datafield: 'name', width: 250 }, { text: 'Beverage Type', datafield: 'type', width: 250 }, { text: 'Calories', datafield: 'calories', width: 180 }, { text: 'Total Fat', datafield: 'totalfat', width: 120 }, { text: 'Protein', datafield: 'protein' } ] }); }; var initWidgets = function (tab) { switch (tab) { case 0: initGrid(); break; case 1: break; } }; $("#objectModelWindow").jqxWindow({ maxHeight: 1250, maxWidth: 5500, minHeight: 750, minWidth: 850, height: document.documentElement.clientHeight - 90, width: document.documentElement.clientWidth - 100, theme: 'classic', resizable: false, isModal: true, modalOpacity: 0.3, position: { x: 70, y: 70 }, autoOpen: false }); $("#btn1").click(function () { $('#objectModelWindow').jqxWindow('open'); $('#tab1').jqxTabs({ width: '100%', height: '30%', theme: 'classic', initTabContent: initWidgets }); $('#tab2').jqxTabs({ width: '100%', height: '80%', theme: 'classic' }); }); }); </script></head><body> <button id="btn1"> Show window! </button> <div id="objectModelWindow"> <div id="WHeader"> Header</div> <div id="WContent"> <div id="tab1"> <ul style='margin-left: 20px;'> <li>Tab 1.1</li> <li>Tab 1.2</li> </ul> <div> Grid: <div id="jqxgridDR"> </div> </div> <div> Content 2 </div> </div> <div id="tab2"> <ul style='margin-left: 20px;'> <li>Tab 2.1</li> <li>Tab 2.2</li> </ul> <div> Content 1 </div> <div> Content 2 </div> </div> </div> </div></body></html>
And here is the contents of beverages.txt:
[{ "id": "1", "name": "Hot Chocolate", "type": "Chocolate Beverage", "calories": "370", "totalfat": "16g", "protein": "14g" }, { "id": 2, "name": "Peppermint Hot Chocolate", "type": "Chocolate Beverage", "calories": "500", "totalfat": "16g", "protein": "13g"}, { "id": "3", "name": "Salted Caramel Hot Chocolate", "type": "Chocolate Beverage", "calories": "450", "totalfat": "16g", "protein": "13g"}]
