jQuery UI Widgets Forums Grid Issue with Filter Options for Grid Columns
This topic contains 2 replies, has 2 voices, and was last updated by  Dattaram Phansekar 13 years, 1 month ago.
  • There seems to be some issue with the filtering option provided on each column header.
    The “Sorting/Grouping” options do not work, till I do some action on individual column.
    If I filter “Column1” and then try to use the filtering options, it work only for this column but not for other columns. Even the option works fine for Column1 till I clear the filters.
    Strange issue…..
    Also, when put 3 grids on a single page, the filtering options menu rendered is of very small size. It comes back to normal size if I do some action (filtering/grouping on the grid).
    Hi Dattaram Phansekar,
    I tried to reproduce the reported issues, but without avail.
    In my test sample I added 3 grids. Each Grid is with enabled Filtering, Sorting and Grouping. When I filter a column, I am able to Sort, Group or Filter by any column. I also can’t reproduce the issue regarding the Grid’s Menu. I am testing with jQWidgets 1.8. Could you please send us your test code which reproduces the reported issue? Please, write your test browser’s name, version and jQWidgets version.
    Here’s my code:
    <title id='Description'>This example illustrates the Grid filtering feature. Move the mouse cursor over a column header and click the dropdown button to open the filtering menu.
    </title>
    <script type="text/javascript" src="../../scripts/jquery-1.7.1.min.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxgrid.grouping.js"></script>
    var theme = '';
    var data = generatedata(500);
    localdata: data,
    datatype: "array"
    $("#jqxgrid").jqxGrid(
    width: 670,
    source: source,
    groupable: true,
    autoshowfiltericon: true,
    { text: 'Order Date', datafield: 'date', width: 100, cellsformat: 'd' },
    { text: 'Unit Price', datafield: 'price', cellsalign: 'right', cellsformat: 'c2' }
    $("#jqxgrid2").jqxGrid(
    width: 670,
    source: source,
    groupable: true,
    $("#jqxgrid3").jqxGrid(
    width: 670,
    source: source,
    groupable: true,
    <div id="jqxgrid">
    <div id="jqxgrid2">
    <div id="jqxgrid3">
    Thanks for the reply.
    It seems that my issue is resolved. I was setting couple of properties of the grid twice. The issue could have been due to that.
