jQuery UI Widgets › Forums › Grid › is Unique column property avaliable and how?
Tagged: column, edit, editing, grid, inline, Inline editing, jqxgrid, unique, validate, validation
This topic contains 5 replies, has 2 voices, and was last updated by Dimitar 10 years, 11 months ago.
Hi All;
Unfortunately, I cannot find and use column unique property in Jqxgrid. Is it avaliable? is a feature?
How can I do this for inline editing?Hi ziyahan,
There is no such grid column property but if you share what your requirement is, we may be able to provide you with a workaround.
http://www.jqwidgets.com/Dimitar Hi;
Thanks for your reply.
Shortly, We need a property such as this :
We have a table. The table has a some unique column. For example, the column that named “code” is unique. But We cannot control column value before write to database. If you provide a unique column property, we will check this value validate or not before Model/Backend operation.For example. We have a table like this :
code – value
_________________
a – b
c – dIf I enter “a” value for code column again, Grid should throw an error. “This column should be included unique value”…
Hi ziyahan,
Here is how to achieve this functionality, using the validation callback function (note the first column). The example is based on the demo Default Functionality.
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript"> $(document).ready(function () { var url = "../sampledata/products.xml"; // prepare the data var source = { datatype: "xml", datafields: [ { name: 'ProductName', type: 'string' }, { name: 'QuantityPerUnit', type: 'int' }, { name: 'UnitPrice', type: 'float' }, { name: 'UnitsInStock', type: 'float' }, { name: 'Discontinued', type: 'bool' } ], root: "Products", record: "Product", id: 'ProductID', url: url }; var cellsrenderer = function (row, columnfield, value, defaulthtml, columnproperties, rowdata) { if (value < 20) { return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #ff0000;">' + value + '</span>'; } else { return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #008000;">' + value + '</span>'; } } var dataAdapter = new $.jqx.dataAdapter(source, { downloadComplete: function (data, status, xhr) { }, loadComplete: function (data) { }, loadError: function (xhr, status, error) { } }); // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: 850, source: dataAdapter, pageable: true, autoheight: true, sortable: true, altrows: true, enabletooltips: true, editable: true, selectionmode: 'multiplecellsadvanced', columns: [ { text: 'Product Name', columngroup: 'ProductDetails', datafield: 'ProductName', width: 250, validation: function (cell, value) { var validationResult = true; var rows = $('#jqxgrid').jqxGrid('getrows'); for (var i = 0; i < rows.length; i++) { if (i == cell.row) { break; } if (rows[i].ProductName == value) { validationResult = false; break; } }; if (validationResult == false) { return { result: false, message: "Values in this column must be unique" }; } return true; } }, { text: 'Quantity per Unit', columngroup: 'ProductDetails', datafield: 'QuantityPerUnit', cellsalign: 'right', align: 'right', width: 200 }, { text: 'Unit Price', columngroup: 'ProductDetails', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', cellsformat: 'c2', width: 200 }, { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 }, { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued' } ], columngroups: [ { text: 'Product Details', align: 'center', name: 'ProductDetails' } ] }); }); </script> </head> <body class='default'> <div id='jqxWidget' style="font-size: 13px; font-family: Verdana; float: left;"> <div id="jqxgrid"> </div> </div> </body> </html>
http://www.jqwidgets.com/Hi Dimitar;
Thanks for this application and your interest.
This is cutely. However, I think, you should add this method as default functionality among to column properties.
I hope, you will add this to your todo list for your next relases..Hi ziyahan,
Thank you for your feedback. We will consider implementing this feature.
