jQuery UI Widgets › Forums › Editors › MaskedInput › Input Mask and MVC Model
Tagged: angular maskedinput, bootstrap maskedinput, javascript maskedinput, jquery maskedinput, jqwidgets maskedinput, jqxmaskedinput, maskedinput MVC
This topic contains 3 replies, has 2 voices, and was last updated by Hristo 8 years, 9 months ago.
AuthorInput Mask and MVC Model Posts
I use the javascript routine (this is in an file not embedded in the view) below to set masked input on two MVC Views.
The Model binding saves the mask and input when the data is saved to the database. This is not a problem but when I retrieve the data, It will not display correctly.
How do I get this to work correctly? The setting of the ‘val’ syntax is a different format and does not work here.
Please advise.
(We have an enterprise license for Charlotte County BCCfunction applyMasks(formname) {
$(document).ready(function () {if (formname == ‘create’) {
$(‘#fedID’).jqxMaskedInput({ mask: ‘##-#######’, theme: ‘energyblue’ });
$(‘#fedID’).select();
}$(‘#BusinessPhone’).jqxMaskedInput({ width: ‘100%’, mask: ‘(###) ###-####’, theme: ‘energyblue’ });
$(‘#BusinessPhone’).jqxMaskedInput({ value: ‘@Model.BusinessPhone’ });$(‘#BusinessPhone’).on(‘click’, function () {
$(‘#BusinessPhone’).select();
$(‘#CellPhone’).on(‘focus’, function() {
$(‘#CellPhone’).jqxMaskedInput({ width: ‘100%’, mask: ‘(###) ###-####’, theme: ‘energyblue’ });
$(‘#CellPhone’).jqxMaskedInput({ value: ‘@Model.CellPhone’ });
$(‘#CellPhone’).select();
});$(‘#FaxPhone’).on(‘click’, function () {
$(‘#FaxPhone’).jqxMaskedInput({ width: ‘100%’, mask: ‘(###) ###-####’, theme: ‘energyblue’ });
$(‘#FaxPhone’).jqxMaskedInput({ value: ‘@Model.FaxPhone’ });
$(‘#FaxPhone’).select();
$(‘#EmergencyContactPhone’).on(‘click’, function () {
$(‘#EmergencyContactPhone’).jqxMaskedInput({ width: ‘100%’, mask: ‘(###) ###-####’, theme: ‘energyblue’ });
$(‘#EmergencyContactPhone’).jqxMaskedInput({ value: ‘@Model.EmergencyContactPhone’ });
$(‘#EmergencyContactPhone’).select();
}Hello janets,
Do you have some error messages in the console?
Also please check the format of the value that you set on this particular MaskedInput.
(Hint: If you try to set number 1234 on [#]-### the result will be [2]-___ correct is to set string “[1]-234”)Best Regards,
Hristo HristovjQWidgets team
http://www.jqwidgets.comIf I save the value into the database as masked IE: (941) 475-7981 and I retrieve it and set the masked field using Value: the fields displays ( ) ___-____. When I inspect the DOM the value: (941) 475-7981 the aria-valuenow=”(___) ___-____”. The only way to get this to display is to strip the mask and pass all digits. The documentation is not clear as the difference between val and value. or not clear to me.
I would prefer to store the mask in the database.Hello janets,
We have discussion about this. Please, take a look this topic:
http://www.jqwidgets.com/community/topic/problem-re-populating-masked-input/#post-82511Best Regards,
