jQuery UI Widgets Forums Lists DropDownList Incorrect position for up-direction
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 9 years ago.
  • Incorrect position for up-direction #83938
    Reony
    Has there been any bugs/encounters of the upward direction, creating a gap?
    There’s a CSS class that’s being used from the theme we generated, that is for the “up” direction, but the list is opening downwards. As you see, it’s inside a table too.
    (If that link doesn’t work, go here: http://jmp.sh/8gVdtqM)
    Any help would be appreciated!
    Incorrect position for up-direction #83942
    Hi Reony,
    i see no up direction or any such settings in that. Also the dropdownlist style is not produced by us so we do not know what is the problem in your page. Update jqwidgets, prepare and share jsfiddle example and we will look what is the issue. Also in general it is not very good approach to use tables for layouts and to place div tags in td tags
    Regards
    Peter
