jQuery UI Widgets Forums Chart In Stacked chart Hide legend if not data for particular data
This topic contains 5 replies, has 2 voices, and was last updated by  Dimitar 10 years, 3 months ago.
  • arunthatham
    In a stacked chart out of three legends for example if none of the bar has value greater than 0 then i need to hide the legend as well.
    How to Implement?
    arunthatham
    I MEAN OUT OF RUNNING ,SWIMMING,CYCLING.iF CYCLING IS ZERO FOR ALL RECORD THEN THE CYCLING LEGEND HAS TO GET HIDE.Remaining two legend has to be shown.
    Hello arunthatham,
    Here is how to hide a particular series’ legend:
    $('#chartContainer .jqx-chart-legend-text').eq(0).parent().hide();
    where chartContainer is the id of the jqxChart and 0 is the series index.
    arunthatham
    Where i need to add this line of code?
    I added at before processing part it didnt work.
    arunthatham
    I added at load complete event it worked as expected but clicking on someother legend this legend comes back automatically.
    How to fix it?
    Hello arunthatham,
    You can use the recursive function addhandler demonstrated in the following example as a workaround:
        <script type="text/javascript" src="../../jqwidgets/jqxdraw.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxchart.core.js"></script>
                var sampleData = [
                        { Day: 'Monday', Running: 30, Swimming: 5, Cycling: 25, Riding: 10 },
                        { Day: 'Tuesday', Running: 25, Swimming: 25, Cycling: 0, Riding: 15 },
                        { Day: 'Wednesday', Running: 30, Swimming: 5, Cycling: 25, Riding: 25 },
                        { Day: 'Thursday', Running: 35, Swimming: 25, Cycling: 45, Riding: 15 },
                        { Day: 'Friday', Running: 5, Swimming: 20, Cycling: 25, Riding: 5 },
                        { Day: 'Saturday', Running: 30, Swimming: 0, Cycling: 30, Riding: 30 },
                        { Day: 'Sunday', Running: 60, Swimming: 45, Cycling: 5, Riding: 20 }
                // prepare jqxChart settings
                var settings = {
                    title: "Fitness & exercise weekly scorecard",
                    description: "Time spent in vigorous exercise by activity",
                    enableAnimations: true,
                    showLegend: true,
                    source: sampleData,
                    xAxis:
                            dataField: 'Day',
                            showTickMarks: true,
                            tickMarksInterval: 1,
                            tickMarksColor: '#888888',
                            unitInterval: 1,
                            showGridLines: false,
                            gridLinesInterval: 1,
                            gridLinesColor: '#888888',
                            axisSize: 'auto'
                    colorScheme: 'scheme06',
                    seriesGroups:
                                type: 'stackedcolumn',
                                columnsGapPercent: 100,
                                seriesGapPercent: 5,
                                valueAxis:
                                    unitInterval: 10,
                                    minValue: 0,
                                    maxValue: 120,
                                    displayValueAxis: true,
                                    description: 'Time in minutes',
                                series: [
                                        { dataField: 'Running', displayText: 'Running' },
                                        { dataField: 'Swimming', displayText: 'Swimming' }
                                  valueAxis:
                                      unitInterval: 10,
                                      minValue: 0,
                                      maxValue: 120,
                                      visible: false,
                                  series: [
                                          { dataField: 'Riding', displayText: 'Riding' },
                                          { dataField: 'Cycling', displayText: 'Cycling' }
                // setup the chart
                $('#chartContainer').jqxChart(settings);
                function addhandler() {
                    $('#chartContainer .jqx-chart-legend-text').parent().click(function () {
                        addhandler();
                    addhandler();
        <div id='chartContainer' style="width: 850px; height: 500px;" />
