jQuery UI Widgets › Forums › Layouts › Splitter › iframe scrolling issue using with treeview, splitter and tabs
This topic contains 7 replies, has 3 voices, and was last updated by Dimitar 8 years, 2 months ago.
I am using iframe to load the content of sub pages inside the tabs, but initially when the page is loaded the iframe width is not appeared 100%, although the width property is set to 100%, but when I re-size the splitter, the width is stick to 100%.
The initial load looks like this.
When you scroll the scroll views like this.
Following is the whole code of this page:
<code>
<html lang=”en”>
<title id=’Description’>MIS</title>
<link rel=”stylesheet” href=”assets/jqwidgets/styles/jqx.base.css” type=”text/css” />
<link rel=”stylesheet” href=”assets/jqwidgets/styles/jqx.arctic.css” type=”text/css” />
<script type=”text/javascript” src=”assets/scripts/jquery-1.10.2.min.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxcore.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxsplitter.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxtabs.js”></script>
<script type=”text/javascript” src=”assets/scripts/gettheme.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxbuttons.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxpanel.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxtree.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxexpander.js”></script>
<script type=”text/javascript” src=”assets/jqwidgets/jqxmenu.js”></script><script type=”text/javascript”>
var theme = “arctic”;$(‘#mainSplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, resizable: ‘false’, panels: [{ size: ‘200px’ }, { size: ‘80%’ }] });
$(“#jqxExpander”).jqxExpander({toggleMode: ‘none’, showArrow: false, width: “100%”, height: “100%”, theme: theme,
initContent: function () {
$(‘#jqxTree’).jqxTree({ height: ‘100%’, width: ‘100%’, theme: theme });
//$(‘#iframe’).html(‘<iframe src=”http://localhost:8080/jqwidget/demos/php/billing_form.htm” scrolling=”yes” style=”width:99%;height:98%;” frameborder=”1″></iframe>’);}
});$(‘#jqxTabs’).jqxTabs({ width: ‘100%’, height: ‘100%’, showCloseButtons:true, selectionTracker: true, position: ‘top’, theme: theme });
<style type=”text/css”>
html, body
height: 100%;
width: 100%;
margin: 0px;
padding: 0px;
overflow: hidden;
</style></head>
<body>
<div style=”position: absolute; width: 100%; height: 50px;”>
<div style=”position: absolute; width: 100%; height: 50px; z-index: 100;”>
Header
</div><div style=”position: absolute; -moz-box-sizing:border-box; padding-top: 50px; padding-bottom: 20px; width: 100%; height: 100%;”>
<div id=”mainSplitter”>
<div><div id=’jqxWidget’ style=”height:100%”>
<div style=”border: none;” id=’jqxExpander’>
<div>
Feeds</div><div>
<div id=’jqxTree’>
<ul>
<li item-expanded=’true’ id=”t1″>
<img style=’float: left; margin-right: 5px;’ src=’assets/img/contactsIcon.png’ /><span
item-title=”true”>News and Blogs</span>
<ul>
<li>
<img style=’float: left; margin-right: 5px;’ src=’assets/img/favorites.png’ /><span
item-title=”true”>Favorites</span>
<ul>
<li>
<img style=’float: left; margin-right: 5px;’ src=’assets/img/folder.png’ /><span
item-title=”true”>ScienceDaily</span> </li>
</ul>
</li>
<li>
item-title=”true”>Geek.com</span> </li>
<li>
item-title=”true”>CNN.com</span> </li>
</ul>
</li>
<ul>
<li>
<ul>
<li>
</ul>
</li>
<li>
<li>
</ul>
</li>
<ul>
<li>
<ul>
<li>
</ul>
</li>
<li>
<li>
</ul>
</li>
<ul>
<li>
<ul>
<li>
</ul>
</li>
<li>
<li>
</ul>
</li>
<ul>
<li>
<ul>
<li>
</ul>
</li>
<li>
<li>
</ul>
</li>
</ul>
</div><div style=”width:85%”>
<div id=’jqxTabs’>
<ul>
<li style=”margin-left: 10px;” hasclosebutton=’false’>Dashboard</li>
</ul>
<div id=”iframe” style=”max-width:150%; “>
<iframe src=”http://localhost:8080/jqwidget/demos/php/billing_form.htm” frameborder=”0″ vspace=”0″ hspace=”0″ marginwidth=”0″ marginheight=”0″ scrolling=”no” height=”100%” width=”100%”></iframe>
</div><div style=”position: absolute; bottom: 0; width: 100%; height: 20px;”>
Footer
</html></code>
Hello Aemal,
We tested your example for the reported issue but everything works fine on our side. The iframe is initially 100% wide. Please make sure that you are using the latest version of jQWidgets (3.0.3).
http://www.jqwidgets.com/Hello Dimitar,
I have downloaded the latest version but still the same problem, I have recorded a video of the same please watch. I think the width of the iframe is calculating the space that tree is occupying, therefore it is showed beyond the window width, I guess that by the time iframe is initialized the expander/tree control width is not placed or the splitter does is not initiated.
This is a very crucial issue if we couldn’t fix it the application won’t be functional.Hi Aemal,
The issue may originate in the icorrect initialization of your splitter. You cannot have one panel with width in pixels and one – in percent. They should either be both in pixels or in percent.
You also should not set the width of the panels in the HTML:
We hope these tips help you solve your issue.
It worked! 🙂
The problem was that in the splitter I have used one panel width with pixel and one with percent like below:$(‘#mainSplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, panels: [{ size: ‘200px’ }, { size: ‘80%’ }] });
Now that I made it like following it worked:
$(‘#mainSplitter’).jqxSplitter({ width: ‘100%’, height: ‘100%’, panels: [{ size: ‘20%’ }, { size: ‘80%’ }] });
Thanks a heap for your superb support! 🙂
AemalHi Aemal,
We are glad everything works fine and we have been of help. We would appreciate if you also update your YouTube video on the matter.
http://www.jqwidgets.com/Hi,
I am using vertical splitter with 1 panel using Jqxtree and another Jqxtab
However when i try to implement scroll for tree using splitter it does come however it shows two scrolls one for splitter and another under jqxtree.
One under Jqxtree works fine if we scroll down, however for splitter scroll does n’t work if the content is too much for jqxtree.
How to resolve this issue of 2 scroll converting in one scroll
<asp:Content ID=”Content4″ ContentPlaceHolderID=”maincontent” runat=”server”>
<div id=”dashboardSplitter”>
<div id=”splitter-panel” style=”overflow: auto”>
<div id=’fosTreeGrid’ class=”fosTreeGrid”></div>
<div id=”splitter-panel2″>
<div id=”sp2Tabs” class=”fosTreeGrid” style=””>- TEST 1
- TEST 2
<div>
<div>
<div id=”fosTasksGrid” class=”fosTreeGrid”></div>
</asp:Content>this.Init = function () {
self.ElementDashboardSplitter.jqxSplitter({ width: ‘100%’, height: ‘100%’, panels: [{ size: ‘80%’, size: ‘20%’ }] });
self.ElementFOSTreeGridView.jqxTree({ width: ‘100%’, height: ‘100%’ });
self.ElementSP2Tab.jqxTabs({ height: ‘100%’, width: ‘100%’, position: ‘top’, showCloseButtons: true });
self.DownloadInventory();
}Hi snehaljadhav,
Please try removing the border of the jqxTree (as done in the Integration with jqxGrid demo for the grid so that it can fit properly in the jqxSplitter panel). If this does not help solve your issue, please share a jsEditor/JSFiddle example that demonstrates it.
