jQuery UI Widgets Forums Lists DropDownList IE 8 dropdown list problem
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 13 years, 1 month ago.
  • IE 8 dropdown list problem #2975
    AceDZN
    IE8 doesn’t display option text, instead it shows the value of the option. Chrome, Firefox, Opera and Safari show the text correctly.
    for example:
    <select name="direction" auto="1" id="buyselloption" >
    <option value="0">Buy</option>
    <option value="1">Sell</option>
    </select>
    the script I’ve used is:
    $('#buyselloptiondiv').jqxDropDownList('loadFromSelect', 'buyselloption');
    IE 8 dropdown list problem #2999
    Hi AceDZN,
    I tested the DropDownList with the provided code and confirm that the value is displayed.
    You can populate the DropDownList also by using the following code:
    {value: 0, label: "Sell"},
    {value: 1, label: "Buy"}
    // Create a jqxDropDownList
    $("#jqxWidget").jqxDropDownList({ source: source, selectedIndex: 1, width: '200', height: '25' });
    The reported by you issue will be fixed in the next update.
