jQuery UI Widgets › Forums › Grid › IE (11) Randomly but often hits 'long running script'
Tagged: beginupdate, endupdate, grid, IE11, Internet Explorer 11, jqxgrid, updatebounddata
This topic contains 3 replies, has 2 voices, and was last updated by Dimitar 10 years, 5 months ago.
The grid works great in Chrome/Firefox but in IE i’d say 10-20% of the time it gets stuck and you get the ‘..not responding due to long running script’ Is there any way to prevent this?
My grid is initialized like this…
source = { datatype: "xml", type: "POST", formatdata: function (data) { return "{'machineType': 'rdoMySystems', 'selectedPool': 'NA', 'bShowDeleted': 'false', 'bShow24Hours': 'false', 'bShowRedMachines' : 'false', 'selectedProfilingValues' : ''}"; }, datafields: [ { name: 'Id' }, { name: 'Name' }, { name: 'IpAddress' }, { name: 'GpuFamily' }, { name: 'GpuMarketingName' }, { name: 'GpuBoardNubmer' }, { name: 'GpuSku' }, { name: 'CurrentOs' }, { name: 'AvailableOs' }, { name: 'Heartbeat'}, { name: 'SliCapable' }, { name: 'Status' }, { name: 'Driver' }, { name: 'Location' }, { name: 'SystemRam' }, { name: 'Minutes' }, { name: 'Enabled' }, { name: 'IsFavoriteIcon' } ], record: 'MachineViewData', url: 'GridData.asmx/GetMachines' }; dataAdapter = new $.jqx.dataAdapter(source, { contentType: 'application/json; charset=utf-8' }); $("#jqGridMachines").jqxGrid({ source: dataAdapter, theme: 'energyblue', sortable: true, filterable: true, columnsresize: true, selectionmode: 'multiplerowsextended', enabletooltips: true, groupable: true, columnsreorder: true, height: '100%', width: '100%', columns: [ { text: 'Id', dataField: 'Id', name: 'Id', width: 100, filterable: false }, { text: '', dataField: 'IsFavoriteIcon', width: 30, cellsrenderer: faviconrenderer, pinned: true, resizable: false, filterable: false }, { text: '', width: 30, cellsrenderer: vnciconrenderer, pinned: true, resizable: false, filterable: false }, { text: 'Name', dataField: 'Name', name: 'Name', pinned: true, cellclassname: cellconditioncheck, cellsrenderer: propertieslinkrenderer}, { text: 'IP Address', dataField: 'IpAddress', name: 'IpAddress', cellclassname: cellconditioncheck, cellsrenderer: vnclinkrenderer }, { text: 'GPU Family', dataField: 'GpuFamily', name: 'GpuFamily', cellclassname: cellconditioncheck }, { text: 'GPU Mktg. Name', dataField: 'GpuMarketingName', name: 'GpuMarketingName', cellclassname: cellconditioncheck }, { text: 'GPU Board #', dataField: 'GpuBoardNubmer', name: 'GpuBoardNubmer', cellclassname: cellconditioncheck }, { text: 'GPU SKU', dataField: 'GpuSku', name: 'GpuSku', cellclassname: cellconditioncheck }, { text: 'Current OS', dataField: 'CurrentOs', name: 'CurrentOs', cellclassname: cellconditioncheck }, { text: 'Available OS', dataField: 'AvailableOs', name: 'AvailableOs', cellclassname: cellconditioncheck }, { text: 'Heartbeat', dataField: 'Heartbeat', name: 'Heartbeat', cellclassname: cellconditioncheck }, { text: 'SLI?', dataField: 'SliCapable', name: 'SliCapable', cellclassname: cellconditioncheck }, { text: 'Status', dataField: 'Status', name: 'Status', cellclassname: cellconditioncheck }, { text: 'Driver', dataField: 'Driver', name: 'Driver', cellclassname: cellconditioncheck }, { text: 'Location', dataField: 'Location', name: 'Location', cellclassname: cellconditioncheck }, { text: 'System RAM', dataField: 'SystemRam', name: 'SystemRam', cellclassname: cellconditioncheck }, { text: 'Minutes', dataField: 'Minutes', name: 'Minutes', cellclassname: cellconditioncheck }, { text: 'Enabled', dataField: 'Enabled', name: 'Enabled', cellclassname: cellconditioncheck }, ] });
Then on radio button clicks I update it like this..
function UpdateMachinesGrid(rdoType, selectedPool, selectedProfilingValues, bShowDeleted, bShow24Hours, bShowRedMachines) { rowCSS = new Array(); // reset 'cache' on update $('#jqGridMachines').jqxGrid('beginupdate'); source.formatdata = function (data) { return '{machineType: "' + rdoType + '", selectedPool: "' + selectedPool + '", bShowDeleted: "' + bShowDeleted + '", bShow24Hours: "' + bShow24Hours + '", bShowRedMachines: "' + bShowRedMachines + '", selectedProfilingValues: "' + selectedProfilingValues + '"}' }; $("#jqGridMachines").jqxGrid("updatebounddata"); $('#jqGridMachines').jqxGrid('endupdate'); }
The data comes back from the server just fine but then like I said it will just hang, I am assuming in the various rendering functions but I am not 100% sure of that. It works fine (and is MUCH faster in Chrome/Firefox) but a lot of my users still insist on using IE and I can’t have it hanging like this. Any ideas?
Hello lucasgraf,
We recommend you remove the calls to beginupdate and endupdate. The updatebounddata method should not be called between these two. On a side note, you may need to call
dataAdapter.dataBind()
before updatebounddata to ensure the data adapter has the updated data before passing it to the grid.Best Regards,
http://www.jqwidgets.com/I actually just put in the begin/end updates today to see if that would fix the issue, but it doesn’t seem to help. I will remove them.
Is IE just slow due to it’s super slow javascript processing? 90% of the time it works fine, but then occasionally it hits that long script running. If i remove all the condition checks and stuff it is fine…but I need thoseHi lucasgraf,
As far as I can see there are no conditional statements in the provided code. Maybe the issue originates there. If you wish, you can share those lines of code, too.
