jQuery UI Widgets › Forums › Lists › ListBox › Html property does not work properly for addItem.
Tagged: jqwidgets listbox control, ListBox, listbox control
This topic contains 5 replies, has 2 voices, and was last updated by Peter Stoev 11 years, 2 months ago.
I set html property for an input object used in addItem function. First item is added fine. Then I change html property again but for some reason old HTML code is added. Am I doing something wrong? I also tried render and refresh but nothing helps. It happens here as well if you replace this piece of code:
$(‘#jqxButton’).on(‘click’, function () {
$(“#jqxListBox”).jqxListBox(‘addItem’, ‘jQuery’);
});to this:
var i = 0;
$(“#jqxListBox”).jqxListBox(‘addItem’, { html: ‘<span>Item ‘ + (i++) + ‘</span>’});
$(‘body’).append(i + ‘ ‘);
});At this piece of code I also render counter to body to make sure that it is incremented correctly.
Hi Dmitry,
The value identifier of the item is missing here.
<!DOCTYPE html> <html lang="en"> <head> <meta name="keywords" content="jQuery DropDownList, List, ListBox, Popup List, jqxDropDownList, jqxListBox, List Widget, ListBox Widget, DropDownList Widget" /> <meta name="description" content="The jqxListBox represents a widget that contains a list of selectable items."/> <title id='Description'>The jqxListBox represents a widget that contains a list of selectable items. </title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> </head> <body> <div id='content'> <script type="text/javascript"> $(document).ready(function () { var source = [ "Affogato", "Americano", "Bicerin", "Breve", "Café Bombón", "Café au lait", "Caffé Corretto", "Café Crema", "Caffé Latte"]; // Create a jqxListBox $("#jqxListBox").jqxListBox({ source: source, theme: 'energyblue', width: '200px', height: '250px', selectedIndex: 3 }); $("#jqxButton").jqxButton({ theme: 'energyblue' }); var f = 0; $('#jqxButton').on('click', function () { $("#jqxListBox").jqxListBox('addItem', {value: f, html: '<span>Item ' + f + '</span>' }); f++; }); }); </script> <div id='jqxListBox'></div> <div> <input style="margin-top: 20px;" type="button" id='jqxButton' value="Add item" /> </div> </div> </body> </html>
http://www.jqwidgets.com/Hi, Peter!
Thanks for your reply. But for me it does not really make sense. Why do I need to specify this value property? The string is compiled and it looks like “Item 1” – there is no any placeholder or keyword to use this value.
It is also not obvious at API description. It does not say anything about value usage inside the HTML:
Adds a new item to the jqxListBox. Returns ‘true’, if the new item is added or ‘false’ if the item is not added.
The following fields can be used for the new item:
label – determines the item’s label.
value – determines the item’s value.
disabled – determines whether the item is enabled/disabled.
checked – determines whether item is checked/unchecked.
hasThreeStates – determines whether the item’s checkbox supports three states.
html – determines the item’s display html. This can be used instead of label.
group – determines the item’s group.Is it possible to resolve?
Thanks!
Hi Dmitry,
I am sorry that you do not like the solution I suggested you, but that is the only working solution I can propose you.
Thank you for your solution! As long as it solves the issue – it is fine. Actually, problem is not the solution but the API description. This feature is not obvious and it is not described there so there is no any way to understand it from reading documentation. Perhaps, it is good idea to declare and clarify that feature.
Thank you!
Hi Dmitry,
Thanks for the suggestion.
