This topic contains 10 replies, has 6 voices, and was last updated by  Dimitar 9 years, 1 month ago.
Viewing 11 posts - 1 through 11 (of 11 total)
  • fvalbores
    I need to include .
    This can not be done using , is there any way using JQWidgets?
    Thanks in advance
    fvalbores
    I need to include textarea maxlength=”300″ cols=”100″ rows=”3″ wrap=”virtual”.
    Thanks in advance
    Mariya
    Hi fvalbores,
    Thank you for your interest in using jqWidgets. Unfortunately we do not have a textarea widget.
    Best Wishes,
    Mariya
    How to use JQwidgets for textarea input #32910
    Syai
    But manually it can be done by template code.
    jaffamcneill
    Or simply use the Editor widget?
    Hirohito HIOKI
    Hi.
    How to use combination of pageup,down key with Shift key on jqxtextarea?
    Hi Hirohito HIOKI,
    You can use the standard jQuery events such as keydown to achieve this. Here is an example that shows how to alert a message when Shift+Page Up is pressed:
        <script type="text/javascript" src="../../jqwidgets/jqxtextarea.js"></script>
            $(document).ready(function ()
                var quotes = [];
                quotes.push('Life is a dream for the wise, a game for the fool, a comedy for the rich, a tragedy for the poor.');
                quotes.push('Yesterday is not ours to recover, but tomorrow is ours to win or lose.');
                quotes.push('It does not matter how slowly you go as long as you do not stop.');
                quotes.push('Success depends upon previous preparation, and without such preparation there is sure to be failure.');
                quotes.push('Better a diamond with a flaw than a pebble without.');
                quotes.push('To succeed in life, you need two things: ignorance and confidence.');
                quotes.push('A successful man is one who can lay a firm foundation with the bricks others have thrown at him.');
                quotes.push('Sleep is the best meditation.');
                $('#jqxTextArea').jqxTextArea({ placeHolder: 'Enter a sentence', height: 90, width: 300, minLength: 1, source: quotes });
                $('#jqxTextArea').keydown(function (event)
                    if (event.keyCode === 33 && event.shiftKey === true)
                        alert('Shift+Page Up has been pressed.');
    <body class="default">
        <textarea id="jqxTextArea"></textarea>
    Hirohito HIOKI
    Hi
    Thanks for your response.
    But I want to that ‘pageUp&Down’+’Shift-key’ means ‘some text rows is highlight selection’.
    Likely ‘down arrow-key+Shift-key’ means ‘one text row is highlight selection’.
    How to imprements this function?
    Hi Hirohito HIOKI,
    This behaviour depends on the browser itself. Right now, it seems there is a related issue in Chrome, but Shift+Page Up/Page Down works fine in a textarea (and jqxTextArea) in Internet Explorer and Firefox.
    Hirohito HIOKI
    Hi
    Oh! thanks for your information.
    I use ‘jqxTextarea’ instead of ‘HTML basic textarea’ for a while.
    Hioki
    Hi Hioki,
    jqxTextArea contains an HTML textarea element in its structure. That is why the Chrome issue occurs for both jqxTextArea and textarea.
