jQuery UI Widgets › Forums › Grid › how to solve problem with jqxgrid edit cell validation
Tagged: datagrid, edit cell, jquery datagrid, jqxgrid, validation
This topic contains 5 replies, has 2 voices, and was last updated by deniferliyansah 9 years, 5 months ago.
How to validate cell and update to database using this code,
maybe my statement incorrect to get value in cell jqxgrid,
help me to fix this problem
thanks before$(document).ready(function() {
var data1 = {};
var theme = ‘office’;
var source1 =
{ name: ‘kd_bahan’, type: ‘string’},
{ name: ‘nama_bahan’, type: ‘string’},
{ name: ‘kemasan’, type: ‘string’},
{ name: ‘tgl_masuk’, type: ‘number’},
{ name: ‘merek’, type: ‘string’},
{ name: ‘jumlah_stok’, type: ‘string’},
{ name: ‘jumlh_stokterpakai’, type: ‘string’},
{ name: ‘jumlah_totalstok’, type: ‘string’},
{ name: ‘jenis_bahan’, type: ‘string’}],
cache: false,
url: ‘inc/tabel2.php’,
var data = “update=true&jumlah_stok=” + rowdata.jumlah;
data = data + “&kd_bahan=” + rowdata.kd_bahan + “&jenis_bahan=” +rowdata.jenis_bahan;
dataType: ‘json’,
url: ‘inc/updatebahan.php’,
data: data,
// update command is executed.commit(true);
error: function () {
// cancel changes.
commit(false);
filter: function()
$(“#jqxgrid2”).jqxGrid(‘updatebounddata’, ‘filter’);
root: ‘Rows’,
beforeprocessing: function(data1)
source1.totalrecords = data1[0].TotalRows;
};var dataadapter1 = new $.jqx.dataAdapter(source1, {
loadError: function(xhr, status, error)
alert(“Kata kunci yang anda maksud tidak ditemukan!”);
);var validation= function (cell, value,row) {
var Value = $(‘#jqxgrid2’).jqxGrid(‘getcellvalue’, cell.row, ‘jumlah_totalstok’);
var isi=Value.toString();
var data=value.toString();
if ( data>Value) {
$(“#jqxgrid2”).jqxGrid(‘showvalidationpopup’, cell.row, “jumlah”, “Invalid Value”);
}return true;
$(“#jqxgrid2”).jqxGrid(‘hidevalidationpopups’);
}// initialize jqxGrid
width: ‘100%’,
source: dataadapter1,
theme:theme,
pagesize: 5,
pagesizeoptions: [‘5′, ’10’, ’30’],
virtualmode: true,
editable:true,
showfilterrow: true,
selectionmode: ‘none’,
rendergridrows: function()
return dataadapter1.records;
showtoolbar:true,
var me = this;
var container = $(“<div style=’margin: 1px;’></div>”);
var span = $(“<div style=’float: right; margin-right: 1px;’><button class=’btn btn-sm btn-success’ href=’#tambah-surat’ role=’button’ onclick=’getbahan()’ data-toggle=’modal’ id=’tambahbahan’><i class=’fa fa-flask’></i> Tambahkan Data Bahan </button>”);
toolbar.append(container);
container.append(span);
$(“#tambahbahan”).attr(‘disabled’,’disabled’);
$(“#tambahbahan”).prop(‘disabled’,true);
columns: [{ text: ”, datafield: ”, columntype: ‘checkbox’, width: ‘5%’, pinned:true, filterable:false },
{ text: ‘Kode Bahan’, editable: false, datafield: ‘kd_bahan’, width: ‘10%’, filterable:false },
{ text: ‘Nama Bahan’, editable: false, columntype: ‘dropdownlist’, datafield: ‘nama_bahan’, width: ‘30%’ },
{ text: ‘Jumlah Bahan’, datafield: ‘jumlah’, width: ‘30%’,editable:true,validation:validation},
{ text: ‘Jumlah Total Stok Bahan’, editable: false, datafield: ‘jumlah_totalstok’,columntype: ‘numberinput’,editable:false, width: ‘20%’},
{ text: ‘Kemasan’, editable: false, columntype: ‘dropdownlist’, datafield: ‘kemasan’, width: ‘10%’ },
{ text: ‘Merek’, editable: false, columntype: ‘numberinput’, datafield: ‘merek’, width: ‘10%’},
{ text: ‘Jenis Bahan’, editable: false, datafield: ‘jenis_bahan’, width: ‘30%’ }
// select or unselect rows when the checkbox is clicked.
$(“#jqxgrid2”).bind(‘cellendedit’, function (event) {
if (event.args.value) {
$(“#jqxgrid2”).jqxGrid(‘selectrow’, event.args.rowindex);}
else {
$(“#jqxgrid2”).jqxGrid(‘unselectrow’, event.args.rowindex);}
});who understand with this,
please help meHello deniferliyansah,
I would like to share with You this example. Columns ‘Ship Date’, ‘Quantity’ and ‘Price’ have validation.
Please, look at the approach used in the example.
I hope my answer helps you
Hristo HristovjQWidgets team
http://www.jqwidgets.comyeah thanks for your reply Hristo,
i try this example,
and this is the update source :`$(document).ready(function() {
var data1 = {};
var source1 =
cache: false,
dataType: ‘json’,
data: data,
if (productNameUpdate == true) {
commit(true);
// cancel changes.
commit(false);
filter: function()
root: ‘Rows’,
alert(isi);
if ( data>Value) {
return { result: false, message: “isi data dengan benar!!!” };}
return true;
width: ‘100%’,
theme:theme,
pagesize: 5,
virtualmode: true,
editable:true,
showtoolbar:true,
var me = this;
else {
if i try to input data with value < data, this error validation message always been show,
and if i try to use null data this error not show and work fine
help me friendHi deniferliyansah,
In this code:var validation = function (cell, value, row) { var Value = $('#jqxgrid2').jqxGrid('getcellvalue', cell.row, 'jumlah_totalstok'); var isi = Value.toString(); alert(isi); var data = value.toString(); if (data > Value) { return { result: false, message: "isi data dengan benar!!!" }; } return true; }
Raised alert(isi); in the validation will be called each time you do this validation.
I also looked at whether proper verification in IF. In this case, comparing the two strings. (How would You want to compare. The length or alphabeta /or another type)
If You need feel free to ask again.Best Regards,
http://www.jqwidgets.comThanks again, with your respone Hristo,
i find this problem now
and this is update the source:var validation= function (cell, value,row) {
var parse=parseInt(Value);
var parse1=parseInt(value);
if ( parse1 > parse) {
return { result: false, message: “Jumlah bahan yang digunakan lebih dari jumlah bahan tersedia!!!” };
else if (parse1 < 0){
return { result: false, message: “Jumlah bahan tidak boleh kurang dari 0!!!” };
return true;
}alert(isi); in my code before,
i used it to get data or test the result data from value on jqxgrid column jumlah_stok
thank you so much with your respone Hristo
now i can feel free -
