jQuery UI Widgets › Forums › Grid › how to run ajax and display result in row detail of jqxgrid
Tagged: ajax, angular grid, detail, grid, initrowdetails, jquery grid, jqxgrid, row details, rowexpand
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 9 years, 7 months ago.
I am running n ajax when user click on row detail of jqxgrid and to show related result(from another table).
how can I display the details? i am using folowing code:-$=jQuery.noConflict(); $(document).ready(function(){ var url = "/admins/offerchangejson"; // action from where we get the result in json // prepare the data var source = { datatype: "json", datafields: [ { name: 'TimeStamp', type: 'date', map: 'OfferChanged>TimeStamp' }, { name: 'PublishTimeTimeStamp', type: 'date', map: 'OfferChanged>PublishTimeTimeStamp' }, { name: 'UniqueId', type: 'string', map: 'OfferChanged>UniqueId' }, { name: 'Asin', type: 'string', map: 'OfferChanged>Asin' }, { name: 'TimeOfOfferChangeTimeStamp', type: 'date', map: 'OfferChanged>TimeOfOfferChangeTimeStamp' }, ], id: 'OfferChanged>id', url: url, pagesize: 30, }; var dataAdapter = new $.jqx.dataAdapter(source, { beforeLoadComplete: function (records, originalData, c) { for (var i = 0; i < records.length; i++) { if(originalData[i].OfferChanged.TimeStamp=="0"){ records[i].TimeStamp="" }else{ records[i].TimeStamp = new Date(originalData[i].OfferChanged.TimeStamp* 1000) } if(originalData[i].OfferChanged.PublishTimeTimeStamp=="0"){ records[i].PublishTimeTimeStamp="" }else{ records[i].PublishTimeTimeStamp = new Date(originalData[i].OfferChanged.PublishTimeTimeStamp* 1000) } if(originalData[i].OfferChanged.TimeOfOfferChangeTimeStamp=="0"){ records[i].TimeOfOfferChangeTimeStamp="" }else{ records[i].TimeOfOfferChangeTimeStamp = new Date(originalData[i].OfferChanged.TimeOfOfferChangeTimeStamp* 1000) } }; return records; }, }); var expandData = new Array(); // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: '100%', theme: KiouiTheme, source: dataAdapter, filterable: true, showfilterrow: true, pageable: true, autoheight: true, sortable: true, altrows: true, enabletooltips: true, pagesizeoptions: ['30', '60', '90'], selectionmode: 'singlerow', columnsresize: true, rowdetails: true, enablebrowserselection: true, selectionmode: 'singlecell', rowdetailstemplate: { rowdetails: "<div style='margin: 10px;'><ul style='margin-left: 30px;'><li class='title'>Detail</li></ul><div class='detail'></div></div>", rowdetailsheight: 200 }, ready: function () { var data = $('#jqxgrid').jqxGrid('getrows'); for (var i = 0; i < data.length; i++) { expandData.push(false); }; $("#jqxgrid").on("rowclick", function (event) { var column = event.args.column; var rowindex = event.args.rowindex; var columnindex = event.args.columnindex; if (expandData[rowindex] == false) { $('#jqxgrid').jqxGrid('showrowdetails', rowindex); } else { $('#jqxgrid').jqxGrid('hiderowdetails', rowindex); }; }); $('#jqxgrid').on('rowexpand', function (event) { var args = event.args; var row = args.rowindex; var dataRecord = $("#jqxgrid").jqxGrid('getrowdata', row); $.ajax({ url: '/admins/FetchAllOffersFromUniqueIdajax/'+dataRecord.UniqueId, data: row, type: "GET", cache: false, async: true, success: function(response) { amazonofferofferajax(response); } }); expandData[row] = true; }); $('#jqxgrid').on('rowcollapse', function (event) { var args = event.args; var row = args.rowindex; expandData[row] = false; }); }, columns: [ { text: 'Date', datafield: 'TimeStamp', type: 'date', cellsformat: DateTimeFomat}, { text: 'Publish Date', datafield: 'PublishTimeTimeStamp', type: 'date', cellsformat: DateTimeFomat }, { text: 'Offer Changed Date', datafield: 'TimeOfOfferChangeTimeStamp', type: 'date', cellsformat: DateTimeFomat }, { datafield: 'Asin', text: 'Asin' }, ], }); // to remove the filter result $('#clearfilteringbutton').jqxButton({ height: 25,theme: KiouiTheme}); $('#clearfilteringbutton').click(function () { $("#jqxgrid").jqxGrid('clearfilters'); }); }); function offerofferajax(ajaxdata){ var source2 = { datatype: 'json', localdata: ajaxdata, datafields: [ { name: 'Asin', map: 'Offers>Asin', } ] }; var dataAdapter2 = new $.jqx.dataAdapter(source2); var initrowdetails = function (index, parentElement, gridElement, datarecord) { var tabsdiv = null; var detail = null; var title=null; tabsdiv = $($(parentElement).children()[0]); if (tabsdiv != null) { detail = tabsdiv.find('.detail'); title = tabsdiv.find('.title'); var container = $('<div style="margin: 5px;"></div>') container.appendTo($(detail)); var leftcolumn = $('<div style="float: left; width: 50%;"></div>'); var rightcolumn = $('<div style="float: left; width: 50%;"></div>'); container.append(leftcolumn); container.append(rightcolumn); var SubCondition= "<div style='margin: 10px;'><b>Sub Condition :</b> " + datarecord.SubCondition + "</div>"; $(rightcolumn).append(SubCondition); } } // where should i mention jqxgrid1 id to get the detail $("#jqxgrid1").jqxGrid({ theme: KiouiTheme, source: dataAdapter2, initrowdetails:initrowdetails, }); }
<div id='jqxWidget' class="jqwidget-99-percent"> <div id="jqxgrid"></div> <input style="margin-top: 10px;" value="Remove Filter" class="primaryLargeButton" id="clearfilteringbutton" type="button" /> </div>
Hello prianch,
Here is a mockup example showing what you should basically do. Please read the comments under initrowdetails and the rowexpand event handler.
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.aggregates.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript"> $(document).ready(function () { var data = generatedata(5); var source = { localdata: data, datafields: [{ name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'date', type: 'date' }, { name: 'quantity', type: 'number' }, { name: 'price', type: 'number' }], datatype: "array" }; var containers = []; var adapter = new $.jqx.dataAdapter(source); $("#jqxgrid").jqxGrid({ width: 700, autoheight: true, theme: 'energyblue', height: 300, source: adapter, rowdetails: true, rowdetailstemplate: { rowdetails: '<div style="margin: 10px;"></div>', rowdetailsheight: 35 }, initrowdetails: function (index, parentElement, gridElement, datarecord) { container = $($(parentElement).children()[0]); // make the initial Ajax call here and, on "success", append the retrieved data to "container" containers[index] = container; }, columns: [{ text: 'Product', datafield: 'productname', width: 100 }, { text: 'First Name', datafield: 'firstname', width: 90 }, { text: 'Last Name', datafield: 'lastname', width: 90 }, { text: 'Order Date', datafield: 'date', width: 160, cellsformat: 'dd-MMMM-yyyy' }, { text: 'Quantity', datafield: 'quantity', width: 80, cellsalign: 'right' }, { text: 'Unit Price', datafield: 'price', cellsalign: 'right', cellsformat: 'c2' }] }); $('#jqxgrid').on('rowexpand', function (event) { // row's bound index. var rowBoundIndex = event.args.rowindex; if (containers[rowBoundIndex]) { // make the Ajax call here and, on "success", append the retrieved data to "containers[rowBoundIndex]" } }); }); </script> </head> <body class='default'> <div id='jqxWidget'> <div id="jqxgrid"> </div> </div> </body> </html>
