jQuery UI Widgets › Forums › Angular › How to reference jqxGrid component in rendertoolbar callback function
This topic contains 4 replies, has 4 voices, and was last updated by Stanislav 7 years ago.
June 1, 2017 at 12:00 pm How to reference jqxGrid component in rendertoolbar callback function #94035
I am trying to set a toolbar in jqxgrid with search input field using Angular 2 following the example in jqxgrid’s javascript/jQuery example (http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/index.htm#demos/jqxgrid/toolbar.htm)
However, I am struggling to get a reference of the jqxGridComponent in the callback function definition, here is my code segment:
in .html file I have defined:
<jqxGrid (onFilter)=”filterGrid($event)” #gridReference [auto-create]=’false’></jqxGrid>
in my componnent.ts, I have a reference to jqxGrid using ViewChild, but I tried many ways to reference the jqxGrid inside the rendertoolbar function all failed:
@ViewChild(‘gridReference’) assetGrid: jqxGridComponent;
settings: jqwidgets.GridOptions = {
width: 850,
source: this.assetGridDataAdapter,
var me = this;
var oldVal = “”;
input.on(‘keydown’, function (event) {
if (input.val().length >= 2) {
if (me.timer) {
clearTimeout(me.timer);
if (oldVal != input.val()) {
me.timer = setTimeout(function () {
(<any>$(“#gridReference”)).jqxGrid(‘removefilter’, ‘Description’);
var filtergroup = $[‘jqx’].filter();
var filtervalue = input.val();
var filtercondition = ‘contains’;
var filter1 = filtergroup.createfilter(‘stringfilter’, filtervalue, filtercondition);
var filter_or_operator = 1;
// add the filters.
(<any>$(“#gridReference”)).jqxGrid(‘addfilter’, ‘firstname’, filtergroup);
// apply the filters.
(<any>$(“#gridReference”)).jqxGrid(‘applyfilters’);
}, 1000);
oldVal = input.val();
See the bold line.
I have also tried to use:
this.assetGrid.removefilter(‘Description’);
or
me.assetGrid.removefilter(‘Description’);
Can you help?June 2, 2017 at 10:16 am How to reference jqxGrid component in rendertoolbar callback function #94056Hi yongchen45,
Here is the
toolbar
demo written in Angular:app.component.ts
:import { Component, ViewChild } from '@angular/core'; import { jqxGridComponent } from '../assets/jqwidgets-ts/angular_jqxgrid'; @Component({ selector: 'app-root', templateUrl: './app.component.html' }) export class AppComponent { @ViewChild('myGrid') myGrid: jqxGridComponent; myInput: any; oldVal: string = ''; timer: any = setTimeout(_ => { }); source: any = { datatype: 'jsonp', datafields: [ { name: 'countryName' }, { name: 'name' }, { name: 'population', type: 'float' }, { name: 'continentCode' }, { name: 'adminName1' } ], async: false, url: 'http://api.geonames.org/searchJSON', data: { featureClass: 'P', style: 'full', maxRows: 20, username: 'jqwidgets' } }; dataAdapter: any = new $.jqx.dataAdapter(this.source, { formatData: (data: any): any => { if (this.myInput) { data.name_startsWith = this.myInput.val(); return data; } } } ); columns: any[] = [ { text: 'City', datafield: 'name', width: 170 }, { text: 'Country Name', datafield: 'countryName', width: 200 }, { text: 'Population', datafield: 'population', cellsformat: 'f', width: 170 }, { text: 'Continent Code', datafield: 'continentCode', minwidth: 110 } ]; rendertoolbar = (toolbar: any): void => { let container = document.createElement('div'); container.style.margin = '5px'; let span = document.createElement('span'); span.style.cssText = 'float: left; margin-top: 5px; margin-right: 4px;'; span.innerHTML = 'Search City: '; let inputContainer = document.createElement('input'); inputContainer.id = 'myInput'; inputContainer.style.cssText = 'float: left'; container.appendChild(span); container.appendChild(inputContainer); toolbar[0].appendChild(container); this.myInput = jqwidgets.createInstance('#myInput', 'jqxInput', { width: 220, height: 23 }); this.myInput.addEventHandler('keydown', (): void => { if (this.myInput.val().length >= 2) { if (this.timer) { clearTimeout(this.timer); } if (this.oldVal !== this.myInput.val()) { this.timer = setTimeout(() => { this.myGrid.updatebounddata(); }, 1000); this.oldVal = this.myInput.val(); } } else { this.myGrid.updatebounddata(); } }); }; }
app.component.html
:<jqxGrid #myGrid [width]="850" [source]="dataAdapter" [columns]="columns" [showtoolbar]="true" [autoheight]="true" [rendertoolbar]="rendertoolbar"> </jqxGrid>
IvojQWidgets Team
http://www.jqwidgets.com/June 2, 2017 at 2:55 pm How to reference jqxGrid component in rendertoolbar callback function #94062That works like a charm!
Thanks Ivo.
April 6, 2018 at 7:01 am How to reference jqxGrid component in rendertoolbar callback function #99616I have a several grids with toolbars on the page. They rendered dynamically. I mean – I don’t know the count of grids.
And there are buttons on the toolbars of each grid. For example, DeleteRowButton for each grid on the toolbar.How can I get context for button handler of each grid? Should I make unique Id for buttons? How can I bind it? Rendertoolbar function is out of component context. So I can’t get Id of grid to connect grid and his button. How can I bind button of each grid with the corresponding deleting handler?
April 13, 2018 at 9:28 am How to reference jqxGrid component in rendertoolbar callback function #99699Hello Grigoriy,
Can you please send us an example of how you define your dynamic grids with the buttons?
StanislavjQWidgets Team
