jQuery UI Widgets Forums Editors DateTimeInput How to open month/year selector using keyboard navigation?
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 8 years, 2 months ago.
  • keyur
    Hi all,
    I am using DateTimeInput in one of my Grid as ‘datetimeinput’ type column. Using keyboard I am able to open the date selector and can select the date for nearby month, but I can’t use the keyboard to open the month/year selector (which I can by clicking on the top bar, month name). Is there any settings or property I need to set, or any other function I need to call.
    Below is my code for the Grid:
    var data = <?php echo $grid_data ?>;
    localdata: data,
    {name: ‘id’, type: ‘int’},
    {name: ‘firstname’, type: ‘string’},
    {name: ‘lastname’, type: ‘string’},
    {name: ‘gender’, type: ‘string’},
    {name: ‘active’, type: ‘bool’},
    {name: ‘date_of_birth’, type: ‘date’},
    {name: ‘note’, type: ‘string’}
    datatype: “json”
    var cellStyle = function (row, columnfield, value) {
    return ”;
    $(“#user_grid”).jqxGrid(
    width: 500,
    altrows: true,
    rowsheight: 20,
    selectionmode: ‘singlecell’,
    editmode: ‘selectedcell’,
    {hidden: true, datafield: ‘id’, width: 0},
    {text: ‘First Name’, datafield: ‘firstname’, align: ‘center’, width: 80, cellclassname: cellStyle},
    {text: ‘Last Name’, datafield: ‘lastname’, align: ‘center’, width: 80, cellclassname: cellStyle},
    {text: ‘Gender’, datafield: ‘gender’, align: ‘center’, columntype: ‘dropdownlist’, width: 60, cellclassname: cellStyle},
    {text: ‘Active’, datafield: ‘active’, align: ‘center’, columntype: ‘checkbox’, width: 60, cellclassname: cellStyle},
    {text: ‘DOB’, datafield: ‘date_of_birth’, align: ‘center’, columntype: ‘datetimeinput’, formatString: “yyyy-MM-dd”, cellsformat: “yyyy-MM-dd”, width: 100, cellclassname: cellStyle,
    console.log(“asd”);
    var obj = rowdata;
    obj.date = Date.UTC(obj.date.getUTCFullYear(), obj.date.getUTCMonth(),
    obj.date.getUTCDate());
    var data = $.param(obj);
    {text: ‘Note’, datafield: ‘note’, align: ‘center’, width: 120, cellclassname: cellStyle}
    Hi keyur,
    We have no Key access for that in our DateTimeInput or Calendar.
