jQuery UI Widgets › Forums › Grid › How to implement edit in modal popup in grid, modal popup opens on click of icon
Tagged: javascript datagrid, javascript grid, popup editing
This topic contains 4 replies, has 2 voices, and was last updated by Sudeshna23 12 years, 8 months ago.
August 12, 2012 at 7:34 pm How to implement edit in modal popup in grid, modal popup opens on click of icon #6734
I have a grid containing user details whose 2 columns have edit and delete icons in them.On click of icon it opens edit or delete modal popup respectively, using which I should be able to edit or delete the particular row selected. On click of icon the popups open and the values are filled in.Though the cancel button in the popup works, the edit/delete functionalities themselves in the popup donot. Following is the code. Kindly help.
var source = {
datafields: [{ name: ‘UserName’ },
{ name: ‘FirstName’ }, { name: ‘Phone’ }, { name: ‘City’ },
{ name: ‘Discontinued’, type: ‘bool’}],
url: ‘User/GetUsers’,
var editrow = -1;
var deleterow = -1;
$(“#jqxgrid”).jqxGrid({
width: 860,
theme: ‘darkblue’,
selectionmode: ‘singlerow’,
editmode: ‘click’,
groupable: true,
enabletooltips: true,
autoshowfiltericon: true,
columns: [{ columntype: ‘checkbox’, datafield: ‘discontinued’, width: 100 },{ text: ‘UserName’, datafield: ‘UserName’, width: 150 },
{ text: ‘FirstName’, datafield: ‘FirstName’, width: 180 },
{ text: ‘Phone’, datafield: ‘Phone’, width: 200 },
{ text: ‘City’, datafield: ‘City’, width: 120 },
{ text: ‘Edit’, datafield: ‘Edit’, width: 60, cellsrenderer: function () {
return ‘‘;
},{ text: ‘Delete’, datafield: ‘Image’, width: 60, cellsrenderer: function () {
return ‘‘;
$(“#discontinued”).jqxCheckBox({ theme: ‘darkblue’, checked: true });
$(‘#clearfilteringbutton’).jqxButton({ height: 25, theme: ‘darkblue’ });
$(‘#filterbackground’).jqxCheckBox({ checked: true, height: 25, theme: ‘darkblue’ });
$(‘#filtericons’).jqxCheckBox({ checked: false, height: 25, theme: ‘darkblue’ });
// clear the filtering.
$(‘#clearfilteringbutton’).click(function () {
$(“#jqxgrid”).jqxGrid(‘clearfilters’);
// show/hide filter background
$(‘#filterbackground’).bind(‘change’, function (event) {
$(“#jqxgrid”).jqxGrid({ showfiltercolumnbackground: event.args.checked });
// show/hide filter icons
$(‘#filtericons’).bind(‘change’, function (event) {
$(“#jqxgrid”).jqxGrid({ autoshowfiltericon: !event.args.checked });
});// initialize the popup window and buttons.
$(“#popupWindow”).jqxWindow({ width: 250, height: 230, resizable: true, theme: ‘darkblue’, isModal: true, autoOpen: false, cancelButton: $(“#Cancel”), modalOpacity: 0.01 });
$(“#popupWindow1”).jqxWindow({ width: 250, height: 230, resizable: true, theme: ‘darkblue’, isModal: true, autoOpen: false, cancelButton: $(“#CancelD”), modalOpacity: 0.01 });
$(“#Cancel”).jqxButton({ theme: ‘darkblue’ });
$(“#Save”).jqxButton({ theme: ‘darkblue’ });
$(“#CancelD”).jqxButton({ theme: ‘darkblue’ }); //Used in delete modal popup
$(“#Delete”).jqxButton({ theme: ‘darkblue’ });
// update the edited row when the user clicks the ‘Save’ button.
if (editrow >= 0) {
var row = { UserName: $(“#UserName”).val(), FirstName: $(“#FirstName”).val(), City: $(“#City”).val(),
Phone: parseInt($(“#Phone”).jqxNumberInput(‘decimal’))
$(‘#jqxgrid’).jqxGrid(‘updaterow’, editrow, row);
}$(“#Delete”).click(function () {
if (deleterow >= 0) {
var row = { UserName: $(“#UserNameD”).val(), FirstName: $(“#FirstNameD”).val(), City: $(“#CityD”).val(),
Phone: parseInt($(“#PhoneD”).jqxNumberInput(‘decimal’))
$(‘#jqxgrid’).jqxGrid(‘deleterow’, deleterow, row);
$(“#popupWindow1”).jqxWindow(‘hide’);
});var buttonClickDelete = function (event, row) {
deleterow = row;
$(“#popupWindow1”).jqxWindow({ position: { x: parseInt(offset.right) + 60, y: parseInt(offset.top) + 60} });
var dataRecord = $(“#jqxgrid”).jqxGrid(‘getrowdata’, deleterow);
$(“#UserNameD”).val(dataRecord.UserName);
$(“#FirstNameD”).val(dataRecord.FirstName);
$(“#PhoneD”).val(dataRecord.Phone);
$(“#CityD”).val(dataRecord.City);
// show the popup window.
$(“#popupWindow1”).jqxWindow(‘show’);
var buttonClickEdit = function (event, row) {
editrow = row;
$(“#popupWindow”).jqxWindow({ position: { x: parseInt(offset.right) + 60, y: parseInt(offset.top) + 60} });
$(“#UserName”).val(dataRecord.UserName);
$(“#FirstName”).val(dataRecord.FirstName);
$(“#Phone”).val(dataRecord.Phone);
$(“#City”).val(dataRecord.City);
$(“#popupWindow”).jqxWindow(‘show’);
}EditUserName:
FirstName:
Phone:
City:
DeleteUserName:
FirstName:
Phone:
City:
Filter BackgroundShow All Filter IconsAugust 12, 2012 at 7:40 pm How to implement edit in modal popup in grid, modal popup opens on click of icon #6735$(document).ready(function () {
var source = {
var editrow = -1;
var deleterow = -1;
width: 860,
theme: ‘darkblue’,
editmode: ‘click’,
groupable: true,
return ‘‘;
return ‘‘;
$(“#popupWindow”).jqxWindow({ width: 250, height: 230, resizable: true, theme: ‘darkblue’, isModal: true, autoOpen: false, saveButton: $(“#Save”), cancelButton: $(“#Cancel”), modalOpacity: 0.01 });
if (editrow >= 0) {
alert(‘HereDelete’);
deleterow = row;
alert(event);
editrow = row;
}EditUserName:
FirstName:
Phone:
City:
DeleteUserName:
FirstName:
Phone:
City:
Filter BackgroundShow All Filter IconsAugust 12, 2012 at 7:42 pm How to implement edit in modal popup in grid, modal popup opens on click of icon #6736I am unable to enter the html part of the code here- the edit and delete cellsrenderer function return anchor tags within which image tag is present
August 13, 2012 at 4:02 pm How to implement edit in modal popup in grid, modal popup opens on click of icon #6754Hi Sudeshna23,
For editing with Popup see this demo: popupediting.htm.
For formatting of code when you post in the Forum, see this topic: http://www.jqwidgets.com/community/topic/code-formatting/
Best Wishes,
http://www.jqwidgets.comAugust 19, 2012 at 12:56 pm How to implement edit in modal popup in grid, modal popup opens on click of icon #6872Hi,
Following is the solution that I found for my problem. Using this button click event I was able to edit in the popup.
var buttonClickEdit = function (event, row) { // open the popup window when the user clicks a button. id = event.target.id; var value = $("#jqxgrid").jqxGrid('getcellvalue', id, 'UserID'); var offset = $("#jqxgrid").offset(); $("#popupWindow").jqxWindow({ position: { x: parseInt(offset.right) + 60, y: parseInt(offset.top) + 20} }); $("#popupWindow").jqxWindow('setContent', 'Loading...'); alert(urlRedirectEdit + '/' + value); var jqxhr = $.get(urlRedirectEdit + '/' + value, function (data) { //alert(data); $("#popupWindow").jqxWindow('setContent', data); }) .success(function (data) { // alert("Success"); }) .error(function () {// alert("Failure"); }) .complete(function () {// alert("Complete"); }); $("#popupWindow").jqxWindow('show');}
