jQuery UI Widgets Forums Grid How to clear grid contents?
This topic contains 2 replies, has 2 voices, and was last updated by  Alex Min 13 years ago.
  • How to clear grid contents? #3230
    Alex Min
    Hello.
    I was wondering how to clear all of data in grid.
    I need to delete all of data in grid when I click some button.
    But, I’m not sure how to do.
    I tried to use this method. $(‘#grid’).jqxGrid(‘clear’); But, it dosen’t work.
    Please let me know how to delete all of contents in grid.
    var theme = “classic”;
    var data = new Array();
    var rowcnt;
    var dex = [];
    var cntryCd = [];
    var cntryNm = [];
    var portCd = [];
    var portNm = [];
    var generatedata = function (rowscount) {
    var row = {};
    row["number"] = dex[i];
    row["cntryCode"] = cntryCd[i];
    row["cntryName"] = cntryNm[i];
    row["portCode"] = portCd[i];
    row["portName"] = portNm[i];
    data[i] = row;
    return data;
    var source = {
    localdata: generatedata(0),
    datatype: "array"
    $("#jqxGrid").jqxGrid({
    width: 760,
    height:320,
    pagesize: 10,
    autoheight: false,
    altrows: true,
    clear: true,
    enabletooltips: true,
    { text: '', datafield: 'check', columntype: 'checkbox', checkboxes: true, width: 50},
    { text: 'Number', datafield: 'number', cellsalign: 'right', width: 60 },
    { text: 'Country Code', datafield: 'cntryCode', width: 100 },
    { text: 'Country Name', datafield: 'cntryName', width: 200 },
    { text: 'Terminal Code', datafield: 'portCode', width: 100 },
    { text: 'Terminal Name', datafield: 'portName', width: 260 }
    dataAdapter.dataBind();
    $('#TERMINAL_CLEAR_BTN').click(function () {
    $("#jqxGrid").jqxGrid('clear');
    $('#TERMINAL_INQUIRY_BTN').click(function () {
    var sCntryCd = $('#COUNTRY_CD').val().toUpperCase();
    var sCntryNm = $('#COUNTRY_NM').val().toUpperCase();
    var sPortCd = $('#TERMINAL_CD').val().toUpperCase();
    var sPortNm = $('#TERMINAL_NM').val();
    $.getJSON('terminalInquiry.do', {'sCntryCd':sCntryCd, 'sCntryNm':sCntryNm, 'sPortCd':sPortCd, 'sPortNm':sPortNm},function(data) {
    $.each(data, function(index, entry) {
    dex.push(index+1);
    cntryCd.push(entry["cntryCode"]);
    cntryNm.push(entry["cntryName"]);
    portCd.push(entry["portCode"]);
    portNm.push(entry["portName"]);
    rowcnt = index+1;
    source.localdata = generatedata(rowcnt);
    $("#jqxGrid").jqxGrid({ source: source});
    How to clear grid contents? #3232
    Hi Alex Min,
    To clear the Grid contents, you need to use its ‘clear’ method. By looking into your code, I found out that you are defining a ‘clear’ variable when you initialize the Grid. Remove the ‘clear’ definition from the Grid’s constructor and you will be able to use the Grid’s clear method.
    See below:
    The $(“#jqxGrid”).jqxGrid({
    width: 760,
    height:320,
    pagesize: 10,
    autoheight: false,
    altrows: true,
    clear: true,
    { text: ”, datafield: ‘check’, columntype: ‘checkbox’, checkboxes: true, width: 50},
    { text: ‘Number’, datafield: ‘number’, cellsalign: ‘right’, width: 60 },
    { text: ‘Country Code’, datafield: ‘cntryCode’, width: 100 },
    { text: ‘Country Name’, datafield: ‘cntryName’, width: 200 },
    { text: ‘Terminal Code’, datafield: ‘portCode’, width: 100 },
    { text: ‘Terminal Name’, datafield: ‘portName’, width: 260 }
    How to clear grid contents? #3233
    Alex Min
    OMG, I made a mistake. Thank you Peter. It works. Have a great day!
