jQuery UI Widgets › Forums › Angular › How to access component methods after using createInstance?
This topic contains 4 replies, has 2 voices, and was last updated by Ivo Zhulev 6 years, 3 months ago.
If you are using the DockingLayout component and you initialize another component via the
jqwidgets.createInstance()
method, you don’t have any way of calling functions specific to that component.Consider the following:
import { AfterViewInit, Component, OnInit, ViewChild } from '@angular/core'; import { jqxDockingLayoutComponent } from 'jqwidgets-scripts/jqwidgets-ts/angular_jqxdockinglayout'; import { jqxGridComponent } from 'jqwidgets-scripts/jqwidgets-ts/angular_jqxgrid'; import { Folder } from './models/folder.model'; import { LineItem } from './models/line-item.model'; import { MonolithicService } from './services/monolithic.service'; @Component({ selector: 'app-root', templateUrl: './app.component.html', styleUrls: ['./app.component.scss'] }) export class AppComponent implements OnInit, AfterViewInit { @ViewChild('lineItemsGridReference') public lineItemsGridRef: jqxGridComponent; @ViewChild('dockingLayoutReference') public dockingLayout: jqxDockingLayoutComponent; public lineItems: LineItem[] = []; public layout: any[] = this.generateLayout(); public lineItemColumns: any[] = [ { text: 'Code', datafield: 'Code' }, { text: 'Description', datafield: 'Description' }, { text: 'Quantity', datafield: 'Quantity' }, { text: 'Unit of Measure', datafield: 'UnitOfMeasure' }, { text: 'Quantity Factor', datafield: 'Factor' }, { text: 'Resource', datafield: 'Resource' }, { text: 'Labor Hours', datafield: 'LaborHours' }, { text: 'Resource Output', datafield: 'ResourceOutput' }, { text: 'Direct Cost', datafield: 'DirectCost' }, { text: 'Labor', datafield: 'Labor' }, { text: 'Equipment', datafield: 'Equipment' }, { text: 'Material', datafield: 'Material' }, { text: 'Other 1', datafield: 'Other1' }, { text: 'Other 2', datafield: 'Other2' }, { text: 'Other 3', datafield: 'Other3' } ]; public lineItemsSource: any = { datatype: 'array', localdata: this.lineItems, datafields: [ { name: 'Code', type: 'string' }, { name: 'Description', type: 'string' }, { name: 'Quantity', type: 'float' }, { name: 'UnitOfMeasure', type: 'string' }, { name: 'Factor', type: 'string' }, { name: 'Resource', type: 'float' }, { name: 'LaborHours', type: 'float' }, { name: 'ResourceOutput', type: 'float' }, { name: 'DirectCost', type: 'float' }, { name: 'Labor', type: 'float' }, { name: 'Equipment', type: 'float' }, { name: 'Material', type: 'float' }, { name: 'Other1', type: 'float' }, { name: 'Other2', type: 'float' }, { name: 'Other3', type: 'float' } ] }; public lineItemsDataAdapter: any = new jqx.dataAdapter(this.lineItemsSource); private folders: Folder[]; constructor(private readonly monoService: MonolithicService) {} private generateLayout(): any[] { const layout = [ { type: 'layoutGroup', orientation: 'horizontal', items: [ { type: 'tabbedGroup', width: '20%', minWidth: 200, items: [ { type: 'layoutPanel', title: 'Cost Estimate Tree', contentContainer: 'CostEstimateTree', initContent: () => { // initialize a jqxTree inside the Solution Explorer Panel const source: any[] = []; if (this.folders) { this.folders.forEach((f: Folder) => { source.push({ label: f.Description, expanded: false, id: f.WBSFolderID }); }); } jqwidgets.createInstance('#tree-container', 'jqxTree', { theme: this.theme, width: '100%', height: '100%', source: source }); } } ] }, { type: 'layoutGroup', orientation: 'vertical', width: '80%', items: [ { type: 'documentGroup', height: 600, minHeight: 200, items: [ { type: 'documentPanel', title: 'Detail Item Assignments', contentContainer: 'DetailItemAssignmentsPanel', initContent: () => { // initialize a jqxGrid jqwidgets.createInstance('#lineitems-grid-container', 'jqxGrid', { theme: this.theme, width: '100%', height: '100%', source: this.lineItemsDataAdapter, columns: this.lineItemColumns, sortable: true, altrows: true, editable: false }); } } ] }, { type: 'tabbedGroup', height: 200, pinnedHeight: 30, items: [ { type: 'layoutPanel', title: 'Detail Items', contentContainer: 'DetailItemsPanel' } ] } ] } ] } ]; return layout; } public ngOnInit(): void { this.monoService.getFolders().subscribe((_folders: Folder[]) => { this.folders = _folders; // Forces the layout to redraw this.layout = this.generateLayout(); this.dockingLayout.loadLayout(this.layout); }); this.monoService.getLineItems('33554460').subscribe((_lineItems: LineItem[]) => { this.lineItems = _lineItems; this.lineItemsSource.localdata = this.lineItems; this.lineItemsGridRef.updatebounddata(); // THIS WON'T WORK BECAUSE THE METHOD DOESN'T EXSIST }); } }
with this template:
<jqxDockingLayout #dockingLayoutReference [theme]="theme" [height]="800" [layout]="layout"> <div data-container="CostEstimateTree"> <div id="tree-container" #treeContainer> </div> </div> <div data-container="DetailItemAssignmentsPanel"> <!-- Won't be able to access jqxGrid functions since it's a normal div --> <div id="lineitems-grid-container" #lineItemsGridReference> </div> </div> <div data-container="DetailItemsPanel"> <!-- Nothing for now --> </div> </jqxDockingLayout>
How do I call
? Because you getERROR TypeError: _this.lineItemsGridRef.updatebounddata is not a function
errors when attempting to do so.There is no example of anything like this that I can find anywhere and it’s incredibly frustrating.
Hi stackoverflowisbetter2,
When you create the instance, you must assign it to a variable, and through that variable, you can call methods and change props.
const variable = jqwidgets.createInstance('#lineitems-grid-container'......
variable.updatebounddata();
IvojQWidgets Team
http://www.jqwidgets.com/You guys really need to have an example of this in the docs. I’ve spent days trying to figure this out.
In that same vein, how are you supposed to handle tree click events if you use the
createInstance
function?jqwidgets.createInstance('#tree-container', 'jqxTree', { theme: this.theme, width: '100%', height: '100%', onItemClick: this.handleFolderClick(), //that doesn't work source: source });
or for anything. I need to be able to handle click events on grids created via
createInstance
and trees.Hi stackoverflowisbetter2,
For events:
variable.addEventHandler('eventName', event => { // Do something... })
IvojQWidgets Team
