jQuery UI Widgets Forums Grid How Do I Get Grid Values For Processing?
This topic contains 8 replies, has 2 voices, and was last updated by  viperbyte 12 years, 7 months ago.
  • How Do I Get Grid Values For Processing? #7069
    viperbyte
    Hi everybody.
    Can someone please tell/show me how to get the values of a selected row in a grid so that I can do something with them? I plan to open a new aspx page which will have a details form that will have the values from the selected row for an update. This is what I have so far but I don’t know how to get the values in a form that I can use and I’m not sure if i’m going about this correcty or not. Can somone please give me a hand with this?
    $(“#jqxgrid”).bind(‘rowselect’, function (event) {
    var selectedRowIndex = event.args.rowindex;
    $(‘#grid’).jqxGrid(‘selectcell’, selectedRowIndex, ‘ORG_ID’);
    $(‘#grid’).jqxGrid(‘selectcell’, selectedRowIndex, ‘Organization_Name’);
    $(‘#grid’).jqxGrid(‘selectcell’, selectedRowIndex, ‘address_street’);
    $(‘#grid’).jqxGrid(‘selectcell’, selectedRowIndex, ‘address_number’);
    $(‘#grid’).jqxGrid(‘selectcell’, selectedRowIndex, ‘address_city’);
    $(‘#grid’).jqxGrid(‘selectcell’, selectedRowIndex, ‘address_state’);
    How Do I Get Grid Values For Processing? #7079
    Hi viperbyte,
    To get the values of a row, use the Grid’s getrowdata method.
    How Do I Get Grid Values For Processing? #7109
    viperbyte
    Thanks Peter.
    I have it like this now but nothing happens when I click on a row now. Earlier with this code the alert function would work but now I don’t know why it will not work. Any ideas?
    var row = event.args.rowindex;
    var datarow = $(“#jqxgrid”).jqxGrid(‘getrowdata’, row);
    alert(‘booboo’);
    How Do I Get Grid Values For Processing? #7110
    Hi viperbyte,
    ‘getrowdata’ depending on a row index is implemented in this sample: popupediting.htm. Take a look at the code in the buttonclick event handler. The row’s data is used to populate the popup window with data from the clicked row. The row’s index is passed as argument to the getrowdata method.
     buttonclick: function (row) {
    editrow = row;
    var offset = $("#jqxgrid").offset();
    $("#popupWindow").jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} });
    // get the clicked row's data and initialize the input fields.
    var dataRecord = $("#jqxgrid").jqxGrid('getrowdata', editrow);
    $("#firstName").val(dataRecord.firstname);
    $("#lastName").val(dataRecord.lastname);
    $("#product").val(dataRecord.productname);
    $("#quantity").jqxNumberInput({ decimal: dataRecord.quantity });
    $("#price").jqxNumberInput({ decimal: dataRecord.price });
    // show the popup window.
    $("#popupWindow").jqxWindow('show');
    How Do I Get Grid Values For Processing? #7140
    viperbyte
    Thanks Peter.
    I’m closer now than before because of your help. I took the sample you provided and had it somewhat working the way I need. I won’t be using a jqWindow, I’ll be using an aspx page but what was mentioned in the code showed me how to get to the values in a row of a grid. My problem now though is how do I get the row? The code fragment you supplied already had the row value selected and passed in to the code block in the variable “row”. I’ve tried to get the selected row with the below code and it doesnt’ work. When I click on my Edit button a call to a function named test3 is supposed to display one of the grids values but it doesn’t. When I click the Edit button the only thing that happens is that the grid is reloaded. When I hard code a 3 in the call to innerFunction and uncomment the call to innerFunction then information does display. For what it’s worth. But hard coding it is no good of course. How do I get the row index? Please.
    function test3() {
    innerFunction(selectedRowIndex);
    //innerFunction(3);
    function innerFunction(myIndex) {
    editrow = myIndex;
    alert(dataRecord.Organization_Name);
    How Do I Get Grid Values For Processing? #7150
    Hi viperbyte,
    Here’s a working sample with the ‘getrowdata’ method:
    <script type="text/javascript" src="../../scripts/jquery-1.7.2.min.js"></script>
    var theme = '';
    var data = generatedata(200);
    localdata: data,
    datatype: "array"
    // initialize jqxGrid
    width: 670,
    source: source,
    { text: 'Id', datafield: 'id', width: 50 },
    { text: 'Unit Price', datafield: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' },
    { text: 'Total', datafield: 'total', width: 100, cellsalign: 'right', cellsformat: 'c2' }
    // display selected row index.
    $("#jqxgrid").bind('rowselect', function (event) {
    var row = $("#jqxgrid").jqxGrid('getrowdata', event.args.rowindex);
    alert(row.firstname + " " + row.lastname);
    <div id="jqxgrid">
    How Do I Get Grid Values For Processing? #7154
    viperbyte
    Hello Peter,
    By any chance can you provide the generatedata javascript function mentioned in the above code?
    -Juan
    How Do I Get Grid Values For Processing? #7155
    Hi Juan,
    You can find it in the jqxGrid’s demos in the download package.
    How Do I Get Grid Values For Processing? #7156
    viperbyte
    Thank you so much Peter.
    I can breath easier now. I didn’t know I had all that code available to me in the demos folder, good to know. Hopefully I’ll be able to put this little project together finally relativley soon.
    Thanks.
