jQuery UI Widgets Forums Grid Highlight the Column Header on Click
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 11 years, 10 months ago.
  • Highlight the Column Header on Click #23441
    ghunter
    How would I change the color of a column header when a user clicks on it? I tried this but it doesn’t work:
        $("#grid").on("columnclick", function (event) {
    var column = event.args.column;
    $(column).css("background-color:red;");
    Highlight the Column Header on Click #23464
    Hello ghunter,
    Here is an example:
    var theme = getDemoTheme();
    var url = "../sampledata/products.xml";
    datatype: "xml",
    { name: 'ProductName', type: 'string' },
    { name: 'QuantityPerUnit', type: 'int' },
    { name: 'UnitPrice', type: 'float' },
    { name: 'UnitsInStock', type: 'float' },
    { name: 'Discontinued', type: 'bool' }
    root: "Products",
    record: "Product",
    url: url
    var cellsrenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
    if (value < 20) {
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #ff0000;">' + value + '</span>';
    else {
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid(
    width: 670,
    altrows: true,
    enabletooltips: true,
    { text: 'Product Name', datafield: 'ProductName', width: 250 },
    { text: 'Quantity per Unit', datafield: 'QuantityPerUnit', cellsalign: 'right', align: 'right', width: 120 },
    { text: 'Unit Price', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', cellsformat: 'c2', width: 100 },
    { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 },
    { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued' },
    $("#jqxgrid").on("columnclick", function (event) {
    var column = event.args.datafield;
    var headerNumber;
    for (var i = 0; i < source.datafields.length; i++) {
    if (column == source.datafields[i].name) {
    headerNumber = i;
    break;
    $("#jqxgrid .jqx-grid-column-header:eq(" + headerNumber + ")").css("background-color", "Red");
    <span style="font-size: 12px; font-family: Verdana;">Note: To run a sample that includes
    data binding, you must open it via "http://..." protocol since Ajax makes http requests.</span>
    <div id="jqxgrid">
    On a side note, the argument of the .css() function in your example is incorrect. Please check out jQuery’s API documentation on .css().
