jQuery UI Widgets › Forums › TreeGrid › Hierarchical top level
This topic contains 3 replies, has 2 voices, and was last updated by svetoslav_borislavov 1 year, 11 months ago.
AuthorHierarchical top level Posts
How can I get Treegrid hierarchical top level with this json?
var data = [ { "id": "1", "nome": "REDE", "children": [ { "id": "2", "name": "1 - R1", "children": [ { "id": "3", "name": "10 - LJ 10" }, { "id": "4", "name": "11 - LJ 11" }, { "id": "4", "name": "12 - LJ 12" } ] }, { "id": "5", "name": "2 - R2", "children": [ { "id": "6", "name": "20 - LJ 20" }, { "id": "7", "name": "21 - LJ 21" }, { "id": "8", "name": "22 - LJ 22" } ] }, { "id": "9", "name": "3 - R3", "children": [ { "id": "10", "name": "30 - LJ 30" }, { "id": "11", "name": "31 - LJ 31" }, { "id": "12", "name": "32 - LJ 32" } ] } ] }]; var source = { dataType: "json", dataFields: [ { name: "id", type: 'number' }, { name: "name", type: "string" }, { name: "children", type: "array" } ], hierarchy: { root: "children" }, localdata: data, id: "id" }; var dataAdapter = new $.jqx.dataAdapter(source); $('treegrid').jqxTreeGrid( { source: dataAdapter, altRows: true, hierarchicalCheckboxes: true, checkboxes: true, editable: true, height: 511, width: 875, columns: [ { align: 'center',cellsalign: 'left', datafield: 'name',text: 'Filial',width: 400, filterable: false}, ], });
I don’t understand, what you want to achieve. The code you sent creates the ‘What I want’ Grid from the image.
Here is the demo with a similar code to yours: http://jsfiddle.net/956yr7Lb/3/Best regards,
Svetoslav BorislavovjQWidgets Team
https://www.jqwidgets.com/Hi Svetoslav, thanks for reply.
After my post I found that when the json is inside the code it works fine.
When the json comes from the database API, no.
The json api generate exactly the same format as I posted.
Can there be any difference between the two json ?Hi,
May you send us an example in jsfiddle as the following one:
http://jsfiddle.net/0zehvsy6/
In the example from above, the data is a JSON string and it is working.Can you confirm that the JSON is valid?
https://www.jqwidgets.com/ -
