jQuery UI Widgets Forums Grid help with textbox editor…
This topic contains 4 replies, has 2 voices, and was last updated by  Dimitar 10 years, 3 months ago.
  • help with textbox editor… #65532
    Bradford
    I am trying to use the value of one field in the row to determine the editability of another field in the same row. in the code below something is happening which is preventing the paramarrname field from becomming editable. I am unable to determine what.
    Fiddle works in chrome and not at all in IE: http://jsfiddle.net/MysU4/162/
        <title id='Description'>In this sample is illustrated how to create custom editors for jqxGrid. The "First Name" and "Last Name" columns use the jqxInput widget as a cell editor. The "Products" column
            use a jqxDropDownList widget with enabled Checkboxes  as an editor. The "Quantity" column's editor is jqxSlider.
        </title>
        <link rel="stylesheet" href="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/styles/jqx.base.css" type="text/css" />
        <script type="text/javascript" src="http://code.jquery.com/jquery-1.10.2.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxcore.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxdata.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxbuttons.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxscrollbar.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxmenu.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxgrid.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxgrid.edit.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxgrid.columnsresize.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxgrid.sort.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxgrid.selection.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxlistbox.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxdropdownlist.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxcheckbox.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxinput.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/jqwidgets/jqxslider.js"></script>
        <script type="text/javascript" src="http://www.jqwidgets.com/jquery-widgets-demo/scripts/demos.js"></script>
        <script type="text/javascript" src="http://ajax.cdnjs.com/ajax/libs/json2/20110223/json2.js"></script>
            var data = new Array();
            data.push({ "isnull": "false","name":"$result","paramname":"$result","paramnull":"false","paramdir":"IN","paramtype":"String","paramvalue":"","paramarrname":"","paramarrtype":"String","type":"{\"name\":\"$result\",\"type\":\"String\",\"dir\":\"IN\",\"arrayname\":\"\",\"arraytype\":\"String\"}","detail":{"paramarrname":"","paramarrtype":"Strng","paramdir":"IN","paramname":"$result","paramnull":"false","paramtype":"String","paramvalue":"","type":"{\"name\":\"$result\",\"type\":\"String\",\"dir\":\"IN\",\"arrayname\":\"\",\"arraytype\":\"String\"}"}});
            data.push({ "isnull": "false","name":"$smile","paramname":"$smile","paramnull":"false","paramdir":"IN","paramtype":"Double","paramvalue":"","paramarrname":"","paramarrtype":"String","type":"{\"name\":\"$smile\",\"type\":\"Double\",\"dir\":\"IN\",\"arrayname\":\"\",\"arraytype\":\"String\"}","detail":{"paramarrname":"","paramarrtype":"Strng","paramdir":"IN","paramname":"$smile","paramnull":"false","paramtype":"Double","paramvalue":"","type":"{\"name\":\"$smile\",\"type\":\"Double\",\"dir\":\"IN\",\"arrayname\":\"\",\"arraytype\":\"String\"}"}});
            data.push({ "isnull": "false","name":"$manythings","paramname":"$manythings","paramnull":"false","paramdir":"IN","paramtype":"Array","paramvalue":"","paramarrname":"things","paramarrtype":"String","type":"{\"name\":\"$manythings\",\"type\":\"Array\",\"dir\":\"IN\",\"arrayname\":\"things\",\"arraytype\":\"String\"}","detail":{"paramarrname":"things","paramarrtype":"Strng","paramdir":"IN","paramname":"$manythings","paramnull":"false","paramtype":"Array","paramvalue":"","type":"{\"name\":\"$manythings\",\"type\":\"Array\",\"dir\":\"IN\",\"arrayname\":\"things\",\"arraytype\":\"String\"}"}});
                datatype: 'array',
                dataFields: [
                    { name: 'paramname', type: 'string' },
                    { name: 'paramnull', type: 'bool' },
                    { name: 'paramtype', type: 'string' },
                    { name: 'paramdir', type: 'string' },
                    { name: 'paramarrtype', type: 'string' },
                    { name: 'paramarrname', type: 'string' },
                    { name: 'type' }//,,type: 'json'
                localdata: data
            var createMyEditor = function(row, cellValue, editor, cellText, width, height)
                var element = $('<div tabIndex=0 style="position: absolute; top: 50%; left: 50%; margin-top: -7px; margin-left: -10px;"></div>');
                editor.append(element);
                element.jqxCheckBox({ animationShowDelay: 0, animationHideDelay: 0, width: 16, height: 16});
            var initMyEditor = function (row, cellValue, editor, cellText, width, height) {
                var checkBoxHTMLElement = editor.find('div:first');
                checkBoxHTMLElement.jqxCheckBox({ checked: cellValue.toString() == "true" });
            var getMyEditorValue = function (row, cellValue, editor) {
                    return checkBoxHTMLElement.val();
            var createParamTypeEditor = function(row,cellValue,editor,cellText,width,height){
            	editor.jqxDropDownList({autoDropDownHeight: true,  width: width, height: height, source: ['String', 'Date', 'Double','Integer','Array']})
            var initParamTypeEditor = function(row,cellValue,editor,cellText,width,height){
            	editor.jqxDropDownList('selectItem',cellValue);
            var getParamTypeEditorValue = function(row,cellValue,editor,cellText,width,height){
            	return editor.val();
            var createParamDirEditor = function(row,cellValue,editor,cellText,width,height){
            	editor.jqxDropDownList({autoDropDownHeight: true,  width: width, height: height, source: ['IN','OUT']})
            var initParamDirEditor = function(row,cellValue,editor,cellText,width,height){
            var getParamDirEditorValue = function(row,cellValue,editor,cellText,width,height){
            var createParamArrTypeEditor = function(row,cellValue,editor,cellText,width,height){
            var initParamArrTypeEditor = function(row,cellValue,editor,cellText,width,height){
            var getParamArrTypeEditorValue = function(row,cellValue,editor,cellText,width,height){
    		var columns = [
    		                { text: 'Name', datafield: 'paramname', width:'10%', editable : false },
    		                { text: 'Can Be Null', datafield: 'paramnull',columntype: 'custom', width:'10%', editable : true,
    		                    createeditor: createMyEditor, initeditor: initMyEditor, geteditorvalue: getMyEditorValue
    		                      text: 'Type', datafield: 'paramtype', width: '10%', editable : true, columntype: 'dropdownlist',
    		                      createeditor: createParamTypeEditor, initeditor: initParamTypeEditor, geteditorvalue: getParamTypeEditorValue
    		                      text: 'paramdir', datafield: 'paramdir', width: '10%', editable : true, columntype: 'dropdownlist',
    		                      createeditor: createParamDirEditor, initeditor: initParamDirEditor, geteditorvalue: getParamDirEditorValue
    		                      text: 'paramarrtype', datafield: 'paramarrtype', width: '10%', editable : true, columntype: 'dropdownlist',
    		                      createeditor: createParamArrTypeEditor, initeditor: initParamArrTypeEditor, geteditorvalue: getParamArrTypeEditorValue
    		                      text: 'paramarrname', datafield: 'paramarrname', width: '10%', editable : true, columntype: 'textbox'//,
    		                      //createeditor: createParamArrNameEditor, initeditor: initParamArrNameEditor, geteditorvalue: getParamArrNameEditorValue
    		var gridSettings =
    			//editmode: 'click',
    			altrows: true,
                width: '95%',
                autorowheight:true,
                pageable: false,
                pagesize: 5,
                pagesizeoptions: ['5','10','20'],
                columns: columns,
                selectionmode: 'singlecell'
    		var width;
    		$grid = $('#jqxgrid').jqxGrid(gridSettings);
    		$('#jqxgrid').on('cellEndEdit', function (event) {
    			state.currentQuery.Response.Queries.query.queryDetail.queryDetailObj.queryparamdetail[event.args.rowindex][event.args.datafield] = event.args.value;
    		 $("#jqxgrid").bind('cellbeginedit', function (event) {
                 var column = args.datafield;
                 var row = args.rowindex;
                 var value = args.value;
    			 if ((column === 'paramarrtype' || column === 'paramarrname' ) && $('#jqxgrid').jqxGrid('getcellvalue',row, 'paramtype') != 'Array' ){
                      $("#jqxgrid").jqxGrid('endcelledit', row, column, true);
    <div id="jqxgrid"></div>
    help with textbox editor… #65580
    Hello Bradford,
    Your fiddle should work if you remove $(document).ready() (it is not necessary since the onLoad setting is chosen) and use the jQuery version 1.11.0.
    As for your approach – we recommend you use the callback function cellbeginedit (demo) instead of the event of the same name. Please also note that there is no cellEndEdit event, there is cellendedit.
    help with textbox editor… #65696
    Bradford
    This fiddle now works: http://jsfiddle.net/MysU4/165/
    Thanks for the help – still trying to make this work in a single cell in jqxGrid rather than needing two columns that usually will not have anything to display. Please see the other forum post I have open on that:
    http://www.jqwidgets.com/community/topic/custom-editor-and-renderer-with-multiple-elements-wont-work/
    help with textbox editor… #65698
    Bradford
    The demo you linked above for the callback function cellbeginedit actually demonstrates the events
    http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/disableeditingofrows.htm?arctic
                // events
                $("#jqxgrid").on('cellbeginedit', function (event) {
                    var args = event.args;
                    $("#cellbegineditevent").text("Event Type: cellbeginedit, Column: " + args.datafield + ", Row: " + (1 + args.rowindex) + ", Value: " + args.value);
                    $("#cellendeditevent").text("Event Type: cellendedit, Column: " + args.datafield + ", Row: " + (1 + args.rowindex) + ", Value: " + args.value);
    help with textbox editor… #65716
    Hi Bradford,
    This is true, but the main functionality of the demo is implemented with the cellbeginedit callback function. Please note all column definitions:
        { text: 'First Name', columntype: 'textbox', datafield: 'firstname', width: 80, cellbeginedit: cellbeginedit, cellsrenderer: cellsrenderer },
        { text: 'Last Name', datafield: 'lastname', columntype: 'textbox', width: 80, cellbeginedit: cellbeginedit, cellsrenderer: cellsrenderer },
        { text: 'Product', columntype: 'dropdownlist', datafield: 'productname', width: 190, cellbeginedit: cellbeginedit, cellsrenderer: cellsrenderer },
        { text: 'Available', datafield: 'available', columntype: 'checkbox', width: 67, cellbeginedit: cellbeginedit},
        { text: 'Ship Date', datafield: 'date', columntype: 'datetimeinput', width: 110, cellsalign: 'right', cellsformat: 'd', cellbeginedit: cellbeginedit,
            validation: function (cell, value) {
                var year = value.getFullYear();
                if (year >= 2015) {
                    return { result: false, message: "Ship Date should be before 1/1/2015" };
                return true;
            }, cellsrenderer: cellsrenderer
        { text: 'Quantity', datafield: 'quantity', width: 70, cellsalign: 'right', columntype: 'numberinput',
                if (value < 0 || value > 150) {
                    return { result: false, message: "Quantity should be in the 0-150 interval" };
                return true;
            initeditor: function (row, cellvalue, editor) {
                editor.jqxNumberInput({ decimalDigits: 0, digits: 3 });
            }, cellbeginedit: cellbeginedit, cellsrenderer: cellsrenderer
        { text: 'Price', datafield: 'price', cellsalign: 'right', cellsformat: 'c2', columntype: 'numberinput',
                if (value < 0 || value > 15) {
                    return { result: false, message: "Price should be in the 0-15 interval" };
                return true;
                editor.jqxNumberInput({ digits: 3 });
    and the function of the same name defined after source, which is passed to the callback:
    var cellbeginedit = function (row, datafield, columntype, value) {
        if (row == 0 || row == 2 || row == 5) return false;
