jQuery UI Widgets Forums General Discussions Help or Documentation on CSS
This topic contains 3 replies, has 3 voices, and was last updated by  Peter Stoev 12 years, 6 months ago.
  • Help or Documentation on CSS #8796
    DavidSimmons
    I am needing to make application level changes in fonts, types and sizes. I realize you have the them builder, but that does not address the changes I need to make. Is there some documentation you can point me to that will instruct me to the CSS hierarchy.
    This is something like I need…
    For the page this is what need.
    font-size: 80%;
    font-family: Verdana, Geneva, sans-serif;
    All Headings I would like to bold them…
    If possible, I have some columns that need to change the back ground color. Looks like by the API I should use a render but not sure.
    Help or Documentation on CSS #8809
    Hello DavidSimmons,
    In the documentation of every widget, there is a section called Styling and Appearance, which addresses the topic of changing the CSS of the widget. There you can find the classes, whose style you may want to change. For example, here is the Styling and Appearance page for jqxGrid.
    Help or Documentation on CSS #10306
    DavidSimmons
    Is there any plan to expand the Theme Builder to address all the widget details. Also, have you considered allow the use to select a theme and then modify it with theme builder?
    Help or Documentation on CSS #10311
    Hi David,
    The Theme Builder’s purpose is to build general purpose and simple themes with basic look and feel. It will become too complicated if we add all options which are 500+ at present and that’s not the idea of the tool.
