jQuery UI Widgets › Forums › Grid › help~~ I want to automatically add grid
Tagged: agrregates, automatically, column, computed, computed column, details, dynamic, grid, jqxgrid, master-details, server, synchronize, update
This topic contains 19 replies, has 3 voices, and was last updated by Dimitar 9 years, 3 months ago.
e.g.
http://jsfiddle.net/magick344/B2Gma/5/Quantity Unit Price Total
Total = Quantity * Unit Price
can edit ,
editing Quantity and Unit Price,
Total is even more dynamic digitalthank you~
Hello Inverse,
Maybe you are looking for the Computed Column functionality?
http://www.jqwidgets.com/thank you~
If I want to add aggregates: [‘sum’] in total
What should I do
Hi Inverse,
Aggregates are not available for computed columns if they are implemented this way. This issue is discussed in the forum topic Aggregation not working with Cellsrenderer in jqxGrid.
http://www.jqwidgets.com/Hello Dimitar
Aggregates are not available for computed columns?
I tried to read this forum , But less can understand….
Are there other ways ?
Thanks~
Excuse me
I tried to make
{ text: 'Total', datafield: 'amount',cellsalign: 'right', cellsformat: 'n2', aggregates: [{'sum': function (aggregatedValue, currentValue, column, record) { var total = currentValue ; return aggregatedValue + total; }},], aggregatesrenderer: function(aggregates) { var renderstring = aggregates["sum"]; return '<span style="margin-top: 4px; float: right;">' + renderstring + '</span>'; }, cellsrenderer: function (index, datafield, value, defaultvalue, column, rowdata) { var amount = Math.round(rowdata.price) * Math.round(rowdata.quantity); return "<div style='margin: 4px;' class='jqx-right-align'>" + dataAdapter.formatNumber(amount, "n2") + "</div>"; }, }
Aggregation to be effective must be adjusted manually
But I want to let Aggregation be able to automatically calculate
can any one help me Thanks~~
Hi Inverse,
There is no automatic way. The “manual” ways are specified here: http://www.jqwidgets.com/community/topic/computed-column-that-will-sort-and-use-the-cellclass/#post-58260 and here: http://www.jqwidgets.com/community/topic/computed-column-that-will-sort-and-use-the-cellclass/#post-58472.
http://www.jqwidgets.com/Thanks Dimitar
but sorry…
I really do not understand…
Can you give me an example ?
Hello Inverse,
Here is an example. We hope it is helpful to you.
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxnumberinput.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.aggregates.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript"> $(document).ready(function () { var data = generatedata(5); var source = { localdata: data, datatype: "array", updaterow: function (rowid, rowdata, commit) { // synchronize with the server - send update command // call commit with parameter true if the synchronization with the server is successful // and with parameter false if the synchronization failder. commit(true); }, datafields: [ { name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'available', type: 'bool' }, { name: 'quantity', type: 'number' }, { name: 'price', type: 'number' }, { name: 'date', type: 'date' }, { name: 'total', type: 'number' } ] }; var dataAdapter = new $.jqx.dataAdapter(source); // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: 850, autoheight: true, source: dataAdapter, editable: true, selectionmode: 'multiplecellsadvanced', showstatusbar: true, statusbarheight: 25, showaggregates: true, ready: function () { var rowsCount = $("#jqxgrid").jqxGrid("getrows").length; for (var i = 0; i < rowsCount; i++) { var currentQuantity = $("#jqxgrid").jqxGrid('getcellvalue', i, "quantity"); var currentPrice = $("#jqxgrid").jqxGrid('getcellvalue', i, "price"); var currentTotal = currentQuantity * currentPrice; $("#jqxgrid").jqxGrid('setcellvalue', i, "total", currentTotal.toFixed(2)); } }, columns: [ { text: 'First Name', columntype: 'textbox', datafield: 'firstname', width: 80 }, { text: 'Last Name', datafield: 'lastname', columntype: 'textbox', width: 80 }, { text: 'Product', columntype: 'dropdownlist', datafield: 'productname', width: 195 }, { text: 'Quantity', datafield: 'quantity', width: 100, align: 'right', cellsalign: 'right', columntype: 'numberinput', validation: function (cell, value) { if (value < 0 || value > 1500) { return { result: false, message: "Quantity should be in the 0-150 interval" }; } return true; }, createeditor: function (row, cellvalue, editor) { editor.jqxNumberInput({ decimalDigits: 0, digits: 3 }); } }, { text: 'Price', datafield: 'price', align: 'right', cellsalign: 'right', cellsformat: 'c2', columntype: 'numberinput', validation: function (cell, value) { if (value < 0 || value > 1500) { return { result: false, message: "Price should be in the 0-15 interval" }; } return true; }, createeditor: function (row, cellvalue, editor) { editor.jqxNumberInput({ digits: 3 }); } }, { text: 'Total', editable: false, datafield: 'total', cellsalign: 'right', aggregates: ['sum'], cellsformat: 'c2' } ] }); }); </script> </head> <body class='default'> <div id="jqxgrid"> </div> </body> </html>
http://www.jqwidgets.com/Thanks Dimitar~
very very happy you can help meヾ(*´∀`*)ノ
but this example(http://jsfiddle.net/magick344/B2Gma/6/) Seems to be total can not fluctuate of quantity and price
I want to be this effect (http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/computedcolumn.htm?arctic)
and total add aggregates[sum]
Are this code which change it?
What should I do
Can you please help me Thanks~~
Hi Inverse,
Here is an updated version of the example with dynamic update of the “Total” column:
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxnumberinput.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.aggregates.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript"> $(document).ready(function () { var data = generatedata(5); var source = { localdata: data, datatype: "array", updaterow: function (rowid, rowdata, commit) { // synchronize with the server - send update command // call commit with parameter true if the synchronization with the server is successful // and with parameter false if the synchronization failder. commit(true); }, datafields: [ { name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'available', type: 'bool' }, { name: 'quantity', type: 'number' }, { name: 'price', type: 'number' }, { name: 'date', type: 'date' }, { name: 'total', type: 'number' } ] }; var dataAdapter = new $.jqx.dataAdapter(source); // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: 850, autoheight: true, source: dataAdapter, editable: true, selectionmode: 'multiplecellsadvanced', showstatusbar: true, statusbarheight: 25, showaggregates: true, ready: function () { var rowsCount = $("#jqxgrid").jqxGrid("getrows").length; for (var i = 0; i < rowsCount; i++) { var currentQuantity = $("#jqxgrid").jqxGrid('getcellvalue', i, "quantity"); var currentPrice = $("#jqxgrid").jqxGrid('getcellvalue', i, "price"); var currentTotal = currentQuantity * currentPrice; $("#jqxgrid").jqxGrid('setcellvalue', i, "total", currentTotal.toFixed(2)); } }, columns: [ { text: 'First Name', columntype: 'textbox', datafield: 'firstname', width: 80 }, { text: 'Last Name', datafield: 'lastname', columntype: 'textbox', width: 80 }, { text: 'Product', columntype: 'dropdownlist', datafield: 'productname', width: 195 }, { text: 'Quantity', datafield: 'quantity', width: 100, align: 'right', cellsalign: 'right', columntype: 'numberinput', validation: function (cell, value) { if (value < 0 || value > 1500) { return { result: false, message: "Quantity should be in the 0-150 interval" }; } return true; }, createeditor: function (row, cellvalue, editor) { editor.jqxNumberInput({ decimalDigits: 0, digits: 3 }); } }, { text: 'Price', datafield: 'price', align: 'right', cellsalign: 'right', cellsformat: 'c2', columntype: 'numberinput', validation: function (cell, value) { if (value < 0 || value > 1500) { return { result: false, message: "Price should be in the 0-15 interval" }; } return true; }, createeditor: function (row, cellvalue, editor) { editor.jqxNumberInput({ digits: 3 }); } }, { text: 'Total', editable: false, datafield: 'total', cellsalign: 'right', aggregates: ['sum'], cellsformat: 'c2' } ] }); $("#jqxgrid").on('cellendedit', function (event) { // event arguments. var args = event.args; // column data field. var dataField = event.args.datafield; // row's bound index. var rowBoundIndex = event.args.rowindex; // cell value var value = args.value; // cell old value. var oldvalue = args.oldvalue; // row's data. var rowData = args.row; var total; if (dataField == "quantity") { total = value * rowData.price; } else if (dataField == "price") { total = rowData.quantity * value; } $("#jqxgrid").jqxGrid('setcellvalue', rowBoundIndex, "total", total.toFixed(2)); }); }); </script> </head> <body class='default'> <div id="jqxgrid"> </div> </body> </html>
http://www.jqwidgets.com/Hi Dimitar~~
Thank your example ~ Thank you very much for your help~!
I encountered a problem….
‘TypeError: rowData is undefined’
Excuse me, My CODE where is an error
Thanks. I appreciate your help~
var dataFields2 = [ { name:'id', type: 'string'}, { name: 'name', type: 'string'}, { name: 'price', type: 'number'}, { name: 'total', type: 'number'}, { name: 'quantity', type: 'number'}, ]; var source = { datatype: "json", updaterow: function (rowid, rowdata, commit) { commit(true); }, datafields: dataFields, url: 'addcontent.php', root: 'Rows', }; var dataAdapter = new $.jqx.dataAdapter(source); dataAdapter.dataBind(); $("#product").on('rowselect rowunselect', function (event) { var selectedRows = $('#product').jqxGrid('getselectedrowindexes'); var customerIDs = new Array(); for (var j = 0; j < selectedRows.length; j++) { var currentid = $('#product').jqxGrid('getcellvalue', selectedRows[j], "id"); customerIDs.push(currentid); }; var records = new Array(); for (var k = 0; k < customerIDs.length; k++) { var customerID = customerIDs[k]; var length = dataAdapter.records.length; for (var i = 0; i < length; i++) { var record = dataAdapter.records[i]; if (record.id == customerID) { records[records.length] = record; } } }; var dataSource = { datafields: dataFields, localdata: records } var adapter = new $.jqx.dataAdapter(dataSource); // update data source. $("#addcontent").jqxGrid({ source: adapter }); }); $("#addcontent").jqxGrid( { width: 810, height: 250, source: dataAdapter, keyboardnavigation: false, showstatusbar: true, statusbarheight: 25, showaggregates: true, altrows: true, theme: theme, editmode: 'click', editable: true, selectionmode: 'multiplecellsadvanced', ready: function () { var rowsCount = $("#addcontent").jqxGrid("getrows").length; for (var i = 0; i < rowsCount; i++) { var currentQuantity = $("#addcontent").jqxGrid('getcellvalue', i, "quantity"); var currentPrice = $("#addcontent").jqxGrid('getcellvalue', i, "price"); var currentTotal = currentQuantity * currentPrice; $("#addcontent").jqxGrid('setcellvalue', i, "total", currentTotal.toFixed(2)); } }, columns: [ { text: 'product_name', datafield: 'name', width: 150}, { text: 'Quantity', datafield: 'quantity', width: 100, align: 'right', cellsalign: 'right', columntype: 'numberinput', validation: function (cell, value) { if (value < 0 || value > 1500) { return { result: false, message: "Quantity should be in the 0-150 interval" }; } return true; }, createeditor: function (row, cellvalue, editor) { editor.jqxNumberInput({ decimalDigits: 0, digits: 3 }); } }, { text: 'Price', datafield: 'price', align: 'right', cellsalign: 'right', cellsformat: 'c2', columntype: 'numberinput', validation: function (cell, value) { if (value < 0 || value > 1500) { return { result: false, message: "Price should be in the 0-15 interval" }; } return true; }, createeditor: function (row, cellvalue, editor) { editor.jqxNumberInput({ digits: 3 }); } }, { text: 'Total', editable: false, datafield: 'total', cellsalign: 'right', aggregates: ['sum'], cellsformat: 'c2' } ] }); $("#addcontent").on('cellendedit', function (event) { // event arguments. var args = event.args; // column data field. var dataField = event.args.datafield; // row's bound index. var rowBoundIndex = event.args.rowindex; // cell value var value = args.value; // cell old value. var oldvalue = args.oldvalue; // row's data. var rowData = args.row; var total; if (dataField == "quantity") { total = value * rowData.price; } else if (dataField == "price") { total = rowData.quantity * value; } $("#addcontent").jqxGrid('setcellvalue', rowBoundIndex, "total", total.toFixed(2)); });
Hi Inverse,
Your cellendedit code seems fine but you bind your grid source to the undefined (at least in this code snippet) dataFields variable. I think you should have:
datafields: dataFields2,
instead.
Thank very much~~p(^-^q)
I have found problem~
Is a version of the problem
Replace jqwidgets-ver3.5.0 is ok~~
Thank you~~~~!
I’d like to ask a questionhttps://www.youtube.com/watch?v=mZBTpXm-NRY&feature=youtu.be
Master-Details Will always refresh
can i not let him do to affect my price?
Thanks Dimitar~~!!!
Hi Inverse,
From your video, I did not understand what your issue is. Please explain it in detail and, if it is possible, provide us with a JSFiddle example which we can test.
