jQuery UI Widgets Forums Grid Help defining rowdata for updaterow in selectionmode: "singlecell",
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 12 years, 6 months ago.
  • DavidSimmons
    In singlecell edit mode can you help me define what the object rowdata contains in this example. I am trying to send the rowid
    columnname, and value in the ajax if possible….
    var source = {
    cache: false,
    { name: ‘ID’ },
    { name: ‘AppName’ },
    { name: ‘Description’ }
    url: ‘ApplicationData.php’,
    **** Please help me define what the object row data would be *****
    $(“#jqxgrid”).jqxGrid(
    width: 600,
    height: 300,
    selectionmode: “singlecell”,
    { text: ‘ID’, dataField: ‘ID’, width: 60, hidden: false , editable: false},
    { text: ‘AppName’, dataField: ‘AppName’, width: 140, editable: true},
    { text: ‘Description’, dataField: ‘Description’, width: 300, editable: true}
    Hello DavidSimmons,
    The argument rowdata is an object, containing the new value of the updated row. You can learn more about the updaterow property in Grid Data Sources.
